15-10-2011, 12:01 PM | #1 | ||
hi im after some photos of the original tramp rods mounted to a car. i picked up a set and i want to make sure i mount them as per factory. close ups of the mounting points would be super thanks.
15-10-2011, 01:06 PM | #2 | ||
these any good.. 9/73 tramps..
16-10-2011, 10:31 AM | #3 | ||
spot on thanks!
17-10-2011, 03:47 AM | #4 | ||
cheers big ears..
08-11-2011, 09:40 AM | #5 | ||
Is there any difference in length between sedan and coupe?
Pretty sure there were two styles of tramp rod too.. an early and a late model.
08-11-2011, 02:42 PM | #6 | ||
You need to make a nice solid steel crush tube to weld in the chassis , i've done a couple using 1" solid bar, bore a hole through and then weld in the chassis
09-11-2011, 06:48 PM | #7 | ||
What's a tramp rod for?
09-11-2011, 08:42 PM | #8 | ||
Which cars received tramp rods?
10-11-2011, 07:06 PM | #9 | |||
10-11-2011, 07:29 PM | #10 | ||
Which other cars coped the tramps from factory?
10-11-2011, 08:08 PM | #11 | ||
GT's and 351 cars.
10-11-2011, 09:11 PM | #12 | ||
Landau Tragic
To be more specific, XA and XB GT's, P5 LTD's and Landaus. XC cop cars got a single tramp rod. XA with drum brake is usually a straight rod, and XB era disc brakes have the bent rods. Sedan and coupe are the same. The LTD units are longer bent rods.
STOLEN Cosmic blue Landau. Engine and Vin no: JG70PU12931K. Please pm me if you have any info |
10-11-2011, 10:20 PM | #13 | ||
injection is nice, but...
When i had my XB gt, it came with the factory rods. After it led a early demise at Oran park, we transfered everything into a XB falcon 500.
One job was to put the tramp rods in, i measured the GT and drilled in exactly the same spot on the '500... to my shock, there was a crush tube in the chassis aready. This is the car i have now (the green one) and have since used the same hole and crush tube to mount the top control arm of the four link. also, the XE falcons i measured, they locate their top conrtrol arm in the same position!
Proud member of the Clevo Mafia Limetime Green '74 XB Coupe- Classic not Plastic. Blueprint '02 Pursuit 250- Plastic not Classic (yet) Venom '01 AUII Rebel- RIP. Gone to a better place. Winter White '12 FG GT 335 R-Spec - something the wife thrashes daily '05 CRF450X- For getting dirty in the, um, dirt. |
