Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Coupe Club of Australia > Coupe Restoration & Build
Old 21-05-2012, 06:41 PM   #31
XP6
Formerly ST170ish
XP6's Avatar
Default Re: 74xbkoops rebuild
Sweet lookin fat ***!
Nice work Koops
XP6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2012, 03:50 PM   #32
74xbkoop
74xbkoop
74xbkoop's Avatar
Hi Again,
Sorry its been so long since the last post. Have been flat out with work. Thanks for the comments guys and Doc the colour is a pearl metalic.
Back to the build.
After I fitted the sil it was time to refit the door lock panel correctly (not slanted inwards like previously)
Im going to post numerous small sections as the system logs me off and I loose everything before I get to post it. (Bloody computers)
74xbkoop is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2012, 04:01 PM   #33
74xbkoop
74xbkoop
74xbkoop's Avatar
The side boot panel was also removed to be replaced.
The replacement panel usual was crap so I made a new one.
I also had to remove and rebuild this panel. Dont have any photos of this one finished.
Old 18-08-2012, 04:09 PM   #34
74xbkoop
74xbkoop
74xbkoop's Avatar
Then there was a lot of test fitting of the wheel tub and quater. Found out there was a lot to repair on the tub and a lot of adjustments.
There was a lot of hours spent repairing the tub to get it to fit to the guard and getting it all to align.
Old 18-08-2012, 04:26 PM   #35
74xbkoop
74xbkoop
74xbkoop's Avatar
After having the quater on and off making tweeks to alignment for what seemed 100 times It was finally fitted and rewelded back on. The alignment was well worth all the effort.
The lower rear window section fitted at the same time.
Old 18-08-2012, 04:50 PM   #36
74xbkoop
74xbkoop
74xbkoop's Avatar
Now was the time to sort out the mess on the join of the roof and quater.
This section was cut out and I made a new fill section to weld in.
After being fully welded slowly cleaned up the welds.
Old 18-08-2012, 06:20 PM   #37
bionic2006xr6t
bionic2006xr6t's Avatar
Awesome work mate.
Cheers Ryan
bionic2006xr6t is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2012, 06:21 PM   #38
74xbkoop
74xbkoop
74xbkoop's Avatar
The boot rubber channel was then replaced.
And this corner repaired.
Old 18-08-2012, 06:35 PM   #39
74xbkoop
74xbkoop
74xbkoop's Avatar
The seam between the rear beaver panel and boot was also rusted. Cutting it out was the next job
Then makup the outer section.
Old 18-08-2012, 06:45 PM   #40
74xbkoop
74xbkoop
74xbkoop's Avatar
Gradually moving around the car. The lower section behind the rear wheel was cut out and replaced as well as a new inner boot pane made for htis side as well.
Old 18-08-2012, 06:55 PM   #41
74xbkoop
74xbkoop
74xbkoop's Avatar
Next was removing the RHS sil and rusted sections. Support rail was fitted the same as the other side and new sil fitted. all internal panels repaired. Unfortunately not may photos of this part recovered.
The wheels had turned up. I could not wait, Had to put one on to see how they looked.
Very happy.
Old 18-08-2012, 07:17 PM   #42
74xbkoop
74xbkoop
74xbkoop's Avatar
The center roof arial hole was filled.
The rear bumper was fitted to check alignment.
And had to rebuild the RH corner of the rear quater to make them even.
Started to file finish the body section.
Doors and guards fitted to check alignment. Side vents fitted. More Panel work.
Old 18-08-2012, 07:32 PM   #43
74xbkoop
74xbkoop
74xbkoop's Avatar
Once all the file finishing was finished. It was taken back to the booth for coating in high fill.
Reassembled again
Then loaded back up for the trip back home.
Old 18-08-2012, 10:15 PM   #44
74xbkoop
74xbkoop
74xbkoop's Avatar
After getting it back home the replacement drivers side door was repaired. Some rust in the bottom and a new lock section was made and fitted.
Old 18-08-2012, 10:26 PM   #45
74xbkoop
74xbkoop
74xbkoop's Avatar
Now it was time to tackle the engine bay.
With everything removed it was time to repair, Fill holes, remove anything not needed
Old 19-08-2012, 01:02 AM   #46
Phil B
Clevo power!
Phil B's Avatar
Awesome work! The transformation is just unbelievable. And I love the colour, very nice beast
The beast: XB coupe, 302, manual all the way!
Fixing up thread
The purple monster, daily BA XR6 turbo.
Scale Lego Technic XB Coupe with working bits! Build thread
Phil B is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2012, 08:44 AM   #47
falconator
Regular Yobbo
falconator's Avatar
Now thats a rebuild!!
My alcohol content has to much blood in it.
"I BLEED BLUE "
QLD number plate....V8 COUPE !!! for sale,make a offer!
falconator is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2012, 09:20 PM   #48
cedric
top work. very impressive
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2012, 08:46 PM   #49
74xbkoop
74xbkoop
74xbkoop's Avatar
Thanks for the comments guys. Will get a chance to post some more in a couple of weeks. Flat out traveling with work at the moment. Back soon.
Old 20-09-2012, 09:30 PM   #50
BlueBear
Shockwave
BlueBear's Avatar
Colour me gobsmacked.. Can't understand how I missed this till now
Has to be some of the most meticulous work I have ever seen, can't believe you even re-used that rear quarter panel.
I can see why the end result is just awesome.
Hey, if I can help with your 'bloody computers' problem give me a yell, have done a lot of file retrieval over the years, if it's still on there and the drive spins at all, I should be able to get your old pics for you.
Cheers,
BlueBear is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2012, 10:24 PM   #51
74xbkoop
74xbkoop
74xbkoop's Avatar
Thanks Bluebear for the comments and the offer on the computer issues. Unfortunately the drive won't spin any more after it was formatted it failed a short time after. I have another drive that I'm going to change the drive Pcb over to see if I can get it to run again when I get time. Hopefully it will run again. Then I can try and recover the hidden data. Time will tell its a rainy day thing.
See ya
Anthony
Old 20-09-2012, 10:29 PM   #52
BlueBear
Shockwave
BlueBear's Avatar
Cool, sounds like your on the right track PC wise as well.
Looking forward to more updates from you.
Cheers,
Old 04-08-2013, 08:00 PM   #53
74xbkoop
74xbkoop
74xbkoop's Avatar
Hi all,
Sorry for no further details. This year has been hectic at work and now just about to take out the motor for some major upgrades before Echuca. Nothin like leaving it to the last minute. More on the thread will happen after Echuca.
See ya
