Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > ASL automedia
ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link
Old 15-10-2010, 12:29 AM   #1
cainn24
Default Dash clock on a BF XT
Hi guys
Picked up an ICC wiring loom from you guys today that included the analogue dash clock connector. Being that I have a BF with auto-lights I have a hi-series "green" coded BEM. A while ago I picked up a dash clock on eBay that is from a BF Fairlane. After reassembling my ICC tonight using the new loom (looks fantastic with the new facia I also grabbed from you guys today btw) I whacked it back into my car and plugged the clock in only to find that the clock does not light up (everything else about it works).
Sam had mentioned to me that he'd seen this problem before on XT's, but seemed a bit more confident that I'd be fine because my car comes with a hi-series BEM. In any case his optimism was understandably cautious and I was therefore prepared for there to be an issue or two.
Anyway, do any of you guys know if there is a way to resolve this issue? I'd really like to keep all this behind the ICC rather than resort to wiring the clock up to the instrument cluster.
Thanks.
cainn24 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2010, 05:56 AM   #2
cainn24
I have determined through further investigation that the negative dimmer line is not getting passed to the clock loom. This is why I don't have any illumination. For now I have made up an adapter that simply grounds the illumination line. It means of course that the clock will always be fully illuminated regardless of the level of the rest of the instrumentation but I can live with it until I can be bothered removing the ICC again to figure out a proper solution.
Old 08-12-2019, 10:38 PM   #3
Bigredbf
Default Re: Dash clock on a BF XT
Originally Posted by cainn24 View Post
Hi guys
Thanks.
Did you work it out? I just upgraded my single icc to duel icc and clock light not working. Not sure if clock work either. Still need to program b e m code and h I m
Bigredbf is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2019, 06:12 AM   #4
Bigredbf
How did you go I installed a dual zone icc on my bf xt “hi series” on the weekend and got a clock from the wrecker as well. No light, not sure if it’s a faulty clock of wiring? I plugged it into the icc plug for clock
Old 11-12-2019, 08:56 AM   #5
Bigredbf
Ok did some recherch and worked out yes it’s the dimable neg- wire on the 4pin plug. “Dual zone icc have extra plug on top”
One of the 2 black wires both being -neg one is for the constant clock power the other is for the light. To fix can be easy
-Always full illuminated just joint both black wires
-Do dim with dash find which black one is the dim -neg (with light tester find an earth on body, find the constant clock+ on plug, loop clock + with the black wires, the black that the light won’t turn on with is the dim-) power supply is on cluster pinout 19 light blue red illumination output 25w
Old 11-12-2019, 01:10 PM   #6
Magna
Magna's Avatar
Easiest fix is to add the blue/red illumination wire to the 20 pin plug on the BEM. It's missing on low series looms.
Magna is online now   Reply With Quote Multi-Quote with this Post
Old 11-12-2019, 01:42 PM   #7
Bigredbf
Ok I talking about a bf xr cluster. Each cluster might be different. Just realised your talking about the bem. Ok thanks I’ll look at that
Old 11-12-2019, 09:03 PM   #8
Bigredbf
Yep, BEM as the clock plug also connects to the BEM. That's how it is from factory on HI series looms. Also a lot neater than running wires all over the place.
Are you saying to get the power supply still from the cluster pinout 19 to a 20pin plug on the bem which should have an empty slot?
So where do I find this blue/red wire? Or you mean just run a wire any coulor dosnt matter
Old 13-12-2019, 02:12 PM   #9
Bigredbf
I’m thinking there got to be a neg dim wire already at the bem for the icc lights?
So I’m thinking I might just need to make a loop at the bem plugs?
I found a tech write up and there a table with “j6/10 illumination return blk/blu” could this be the empty spot or neg dim return for the icc lights?
Old 11-12-2019, 02:13 PM   #10
Magna
Magna's Avatar
Old 15-12-2019, 04:13 PM   #11
Bigredbf
After pulling car apart and looking the easiest way to get the neg dim was to run from cluster to top of dash “clock” 30cm of wire. Cluster is fairly easy to remove (5 screws rubber flap 2 plugs) If you can remove the icc the cluster is a walk in the park. U might not Evan need to remove icc but I did to investigate
Old 15-12-2019, 04:32 PM   #12
Bigredbf
Brown wire is light + black wire next to it is - dim
