Old 03-04-2012, 10:54 AM   #1
BillC
Default leaking coolant
Hi all, been trying to find a leak in my cooling system and I think I may have found where its coming from. I just recently replaced the water pump and that is not leaking but the alloy spacer that sits just behind the water pump may be. Its about 5 cm thick and I cant see exactly where its leaking but where the coolant is leaking it can only be from there. I rechecked the water pump bolts and managed another 1/4 turn on each of them and I am hoping that will fix the problem. However if it does not have any of you had any experience changing the gasket on it. Any advice would be appreciated
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2012, 10:55 AM   #2
BillC
Default Re: leaking coolant
Sorry, its an AU XR8 Ser 3
Old 15-04-2012, 09:51 AM   #3
LUV DE COUPE
LUV DE COUPE's Avatar
I think I have the same problem leak behind water pump and my heater tap assy at plastic elbow also split had coolant every where. Backed the cap off and managed to drive home 400 Ks home after watching storm beat the doggys last nite
LUV DE COUPE is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2012, 09:56 AM   #4
LUV DE COUPE
Whoops its also a XR8 series III
