Old 18-01-2006, 12:06 PM   #1
s__brown
Default Extra Speakers for an AU ute
I have an AU series 2 ute. It only has speakers in the doors.
I want to know if there is any good spots i can stick some 6x9's that will be big enough to house them?
Also, i'm wondering if the standard CD player will have rear speaker jack already on it, as i dont really want to replace the unit?
1 last thing, is there a simple way of pulling the CD player out to work on it?
Any help would be appreciated.
Old 18-01-2006, 12:15 PM   #2
Mechan1k
Mechan1k's Avatar
In the XLS models there are 5"x7"s mounted in the rear corners behind grilles .... fitting 6x9s might be difficult unless you custom fabricate something to accomodate them.
Not sure if there are grilles already mounted in the XL models or not ... or if it is just carpet though.
I just replaced my 5x7s with Pioneer ones ... mainly because I wanted a "little bit" of rear fill after putting subs behind the seats and 6" splits in the front.
Old 18-01-2006, 06:40 PM   #3
kenz
BOSS Pilot
kenz's Avatar
ive just cut a hole in the carpet on each side underneath those little window things what ever they are called. lol. and ive just got them in there with small bolts through the carpet, theres plenty of room behind the carpet to house them. And yes the factory HU has wires coming from it for the rear speakers. go here for getting it out it mite help you http://www.fordforums.com.au/showthr...ht=au+headunit
cheers
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 09:06 PM   #4
duaned
duaned's Avatar
Why do you need to put coaxials behind you? Grab a 4ch amp, some good 6 1/2inch splits (or 5x7's) and a subwoofer to go behind the seat. This combo will provide great results.
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 08:48 AM   #5
kenz
BOSS Pilot
kenz's Avatar
probably doesnt have that kinda money just lying around. i know i certainly don't thats why ive only got 6x9's behind the seats and i already had them anyway
Black BAII XR8 Ute
Old 19-01-2006, 06:21 PM   #6
SlicAU
or you could do what I did and custom build like a cabin tidy unit behind the seats and mount them into that, so now I have storage space, my normal 4 speakers and some amped 7 by 10 kennies behind the seats
SlicAU is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 08:31 PM   #7
Baboon_AU
Baboon_AU's Avatar
put the 6x9's in speaker boxes and bolt them onto the parcel shelf.
make sure you bolt the boxes in and then install speakers so they are burgular proof.
i have alpine 5x7 in the doors with tweeters in the door frames, an alpine 4 channel amp under passenger seat and kenwood 6x9 in boxes bolted to the parcel shelf...its a mighty fine system
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
