Old 04-10-2006, 06:21 PM   #1
jones_aus
jones_aus's Avatar
Default Best way to run wires through the firewall?
hi
im looking to install a horn / siren thing under the hood, just need to figure out the best way to run speaker cable from the engine bay into the cabin.
with my old eb i ran a amplifier power cable through the clutch cable hole, but i cant seem to locate this for my AU.
its a fairmont ghia if it makes a difference
cheers
jones_aus is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2006, 07:00 PM   #2
Baboon_AU
Baboon_AU's Avatar
if u have an auto it is sealed with a black rubber grommet.. look under master cylinder
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2006, 07:40 PM   #3
TwistedEL
TwistedEL's Avatar
My fairmont had a spare grommet above the accelerator just had to punch a hole in it and work the wire through (8 guage power cable for amp)
On my EL I stuck the amp cable through the same hole as the hood release, you could try that too.
The only problem you'll have is that it's so thin so you'll need something stronger to pull it through (tie it to the end of some coathanger or something)
Old 04-10-2006, 08:14 PM   #4
Whoosha
AU DIE HARD
Whoosha's Avatar
A mate told me of this little trick last night ..drill a hole thru the gromet(not to big) then push the outer case of a pen thru the hole feed your wire s thru it then remove the pen .. :hihi:
Originally Posted by Riksta
Old 04-10-2006, 08:25 PM   #5
TwistedEL
TwistedEL's Avatar
fantastic idea
Old 04-10-2006, 09:25 PM   #6
JC
JC's Avatar
Or you could use an old RBT straw too - they come in handy for something, and they're free!
Ford Performance Club ACT
Old 05-10-2006, 03:45 AM   #7
clontarf_x
Mine actually has a hole to the upper left of the steering column. I assume it is where the grommet for the manual clutch cable is meant to be...
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2006, 12:31 PM   #8
GlennBA
GlennBA's Avatar
Well.. i have a clutch, so i used the hole that the bonnet cable goes through to run wiring to my strobe lights (behind my C2R grill).
GlennBA is offline   Reply With Quote Multi-Quote with this Post
