Old 24-01-2007, 09:15 PM   #1
howesy
howesy's Avatar
Default changing blinker on AU XR8 ????
Any one point us in the right direction on method to save the "oops I broke it"
Would be much appreciated,
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 09:23 PM   #2
AU1XLS
AU1XLS's Avatar
? what part
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 09:23 PM   #3
au2sw
Blown 5L coming
au2sw's Avatar
umm, depends which blinker your talking about.....if its the repeater on the front guards, a small flat blade screw driver slid gently between the guard and the indicator assembly will pop it off (i would recommend though a plastic, thin lever perhaps a plastic knife or kids flat blade...)in the boot..sedan, pull the carpet away take hold of the plug, twist and pull - wagon, pull the panel, then same as sedan. ute im unsure of. front lift the bonnet, grab the plug, twist and pull. hope this helps.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 09:23 PM   #4
Sledgehammer
Sledgehammer's Avatar
front, side, rear?
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 09:29 PM   #5
howesy
howesy's Avatar
the one in the attached picture.
Old 24-01-2007, 09:33 PM   #6
LUXO_8
windsor user
i dont know if the XR's are the same as falcons, but on a falcon you turn the front wheels in a fassion that gives you good access in the wheel well, unclip the plastic cover between the wheel and bumper and go in from there
earlier falcons had an access hole in the engine bay which was eliminated on au's
Old 26-01-2007, 04:09 PM   #7
nikos
mezzo forte
for the side repeaters you dont need to do any prizing - just pull them towards the rear of the car (there will be spring resistance) then pull out
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 04:23 PM   #8
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Same deal on XR's. Just the indicator is located a little bit lower.
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 05:01 PM   #9
XR66XY
Go From Under The Car Follow The Wiring To The Conection And Turn Anti Clock. The Glob Holder Than Comes Out Cange Glob Than Put In Turning Clock Ways. Best Done Jacked Up But Don't Have To Just Stick Your Hand Up In Gap At Corner Of Bar And Have A Feel Around
XR66XY is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 05:22 PM   #10
nikos
mezzo forte
Wow - XR66XY you sure do love holdin shift...
Old 26-01-2007, 05:28 PM   #11
LUXO_8
windsor user
nikos.....if you type the whole reply in caps, the form adjusts it to have caps first letters
Old 26-01-2007, 05:44 PM   #12
nikos
mezzo forte
ah... i see e
