Old 09-10-2006, 06:58 PM   #1
xbgt73
xbgt73's Avatar
Default EF Futura Air Bag Warning Light
My air bag light flashes on and off and then stays on when i start the car. I have checked the fuse and its ok.. any ideas?
Thanks
xbgt73 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 07:08 PM   #2
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
The airbag light flashes out the error codes. Have a look at the following link, and go from there.
http://www.fordmods.com/forums/documents.php?doc=3
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 10:43 PM   #3
NiTrat3
XR6er
i had the same thing with mine - there is a air bag clear code on the computer connecter in the fuse box that you have to earth out to clear the light from the dash...but i can't remember which one it is...it's in the big service manual for ef/els though.
NiTrat3 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 11:05 PM   #4
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
happened to mine after having the dash out to fix the heater core. had to take it to ford to be programed
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
