Old 15-10-2006, 06:02 PM   #1
UltraLowEd
Default Wiring Help Needed!!!!!!!!!!!
If your good at wiring sound systems i need your help
i have bought another amp just wandering how to wire it up
and i have an amp already for my 2 subbys
UltraLowEd is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 06:14 PM   #2
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
its not difficult
red- battery
brown/black-ground
blue-remote
RCA-RCA
not too difficult just need to get the battery wire to the boot i drilleed through my fire wall
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 06:21 PM   #3
UltraLowEd
the rca is the problem my other amp already takes up the 2 rca termanials on the back of the headunit
Old 15-10-2006, 07:10 PM   #4
crannersEL
crannersEL's Avatar
I've got the same problem mate, i'll be taking mine to Jb and getting them to install it.
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 07:17 PM   #5
efgiar
rofl copter
efgiar's Avatar
u need double adapters, and u just use them at the amp side
GQ patrol.
thats all
Old 15-10-2006, 07:28 PM   #6
UltraLowEd
so just use split them at the headunit?
Old 15-10-2006, 07:35 PM   #7
UltraLowEd
Old 15-10-2006, 08:33 PM   #8
JUZXR8
Hmmmmm
JUZXR8's Avatar
split them at the amp
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 10:05 PM   #9
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
i have 2 amps and a 2 year old pioneer head unit with 1 rca and i just used a spliter
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 15-10-2006, 10:16 PM   #10
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
does it make any difference if theres 1 rca output compared to 2 or 3?
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 10:36 PM   #11
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
from what im told that the rca is somthing from 3 to 5 volt and when u split it, they half the voltage but i didnt notice a rats dicks difference
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 15-10-2006, 10:48 PM   #12
DNKPWR
DNKPWR's Avatar
If ur amp has RCA out..use them..i think they call it daisy chaining! lol
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
DNKPWR is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 10:53 PM   #13
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Correct.
Although, not recommended for a high end system.
If you want a high end system, you need a headunit with 2 x RCA out, and Subwoofer out. 3 amps, one for the front split speakers, one for the rear speakers, and a mono block for the sub. Or you can run one 4 channel for fronts and back.
Splitting RCA's is ok to an extent. On a small system, it'll work fine.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 11:34 PM   #14
old_mate
Smash the Boost
old_mate's Avatar
Only thing about splitting is u lose fader control from the H/U. You will have to do it utilising your gains on your amps.
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
