Old 16-10-2006, 03:33 PM   #1
AUCOON
Default Extractors
Does any one have advance extactors? are they any good.
AUCOON is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 04:44 PM   #2
JoesAu
JoesAu's Avatar
everyone i know with a ford has pacemakers, i went with Hi Tech headers. stick to big and well known brands my opinion.
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 06:26 PM   #3
99FalconS
99FalconS
99FalconS's Avatar
Best value Mod you can do.
I have pacemakers on mine. When i picked it up as soon as turned the key you could tell somthing had changed.
99FalconS is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 06:43 PM   #4
Baboon_AU
Baboon_AU's Avatar
yeah go pacies
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 07:30 PM   #5
mattsAU1
mattsAU1's Avatar
Pacies for sure
matsAU1
mattsAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 02:47 PM   #6
AUCOON
Got the Advance extractors fitted today very impressed.
Old 20-10-2006, 03:09 PM   #7
Hibbz
The Mod Bug Has Hit
Hibbz's Avatar
what did they set you back.
Im getting paccie comps and 2.5" redback exhaust and tip fitted for $700
Hibbz is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 06:13 PM   #8
AUCOON
Cost me $475 fitted they retail for $472 got a better price cause i know the guy.
Old 20-10-2006, 06:40 PM   #9
GTWHOA
Just cruisin
GTWHOA's Avatar
I've had the advance extractors on for about 8 months now, im happy with them.
Do you have any pics just to see if there the same as mine?
___________________
BA LTD 5.4
GTWHOA is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 06:42 PM   #10
mattp
mattp's Avatar
I just got my cat back exhaust done in the last couple of months, now I'm thinking of getting some extractors... I can get pacemaker 4499's for $450 fitted, is it worth getting the comps? I spoke to the qld pacemaker distributor and he said unless I'm going to be putting out a lot of power they're not necessary. I'm not intending on doing too much performance wise to the car, so can anyone with non-comp pacies let me know how they go?
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 10:40 PM   #11
JeffAU1
JeffAU1's Avatar
damn thats an awesome price man
:eclipsee_ MY CAR :eclipsee_
JeffAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2006, 10:03 AM   #12
Mechan1k
Mechan1k's Avatar
Well ... if i get rid of my ute ... I have a set of PH4499 (non-comp extractors for the I6) sitting the garage ... NEW ... still in package ... so i might be selling them soon.
They are supposed to fit the facotry LPG vehicles ... but don't (without modification).
Old 21-10-2006, 10:06 AM   #13
jonbays
TL40 Wagon?
I am running the pacemakers PH4480's and i have always been happy with them. Brendan Mock and I have agreed to disagree about them but the before and after dyno results I got from fitting them with a decent exhaust too of course are in my gallery.
They worked for me.
Old 22-10-2006, 01:13 PM   #14
AUCOON
Go to this web site they are the same as mine A692 www.advanceheaders.com.au/html/prod_ford6.html
Old 22-10-2006, 03:32 PM   #15
parker
Originally Posted by Mechan1k
a set of PH4499
Can you please tell me a little more about this? I've been looking at getting a set of extractors for my egas AUII.
parker is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 03:48 PM   #16
Mechan1k
Mechan1k's Avatar
The PH4499s are meant to fit ... but on some they leave a 2-3mm gap ... other's touch the converter without heat shield.
In NSW you are meant to have a 150mm gap between converter and exhaust heatshield.
So far I have replaced my header tank with a slightly smaller BA version and a couple of hoses ... this allows the converter bracket on the shock tower to move forward easily without fouling with the hose going to the radiator.
But I have had a chance to make up a new bracket to move the converter forward and upwards a little to allow fitment of the extractors.
my mechanic wouldn't allow it ... and 4 exhaust shops said the same as well ... they wouldn't touch it unless the converter was moved to allow more room.
Old 22-10-2006, 03:53 PM   #17
parker
So you have to have the converter relocated to fit extractors? Damn!
Old 22-10-2006, 10:48 PM   #18
AUCOON
I got the Advanced extractors fitted, i have Tickford gas and they did not have to move the converter.
Old 23-10-2006, 07:31 AM   #19
parker
Tickford gas - is that the other 'factory' setup? dual fuel? Do you run the green top motor?
Old 23-10-2006, 09:45 AM   #20
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
You can get Tickford gas - dual fuel with a Vialle Converter, silver top motor.
or you can get egas - dedicated gas with a Vialle Converter, green top motor.
Since both converters are identical, i would hazard a guess saying that it would be the same extractor situation for both.
Old 23-10-2006, 11:34 AM   #21
AUCOON
Yep dual fuel silver top
