Old 20-10-2006, 11:16 AM   #1
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
Default Speedo off
Hey guys,
my speedo seems off by alot, i did the 5 speed convertion and since then my speedo has been siting on 50 when im doing 60 and around 85 when im doing 110, i was passing people when i was doing 90 on the free way and i know pwoplw dont drive 85 on a 110km/h freeway,
h have tryed 3 different speed sencers,
i have a digital speedo, and im out of ideas on how to fix it, is it time for a new dash, if so where would i buy one that i could get and then have it set to the same km's
any one got any ideas
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 02:32 PM   #2
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
they can be re-callibrated. try that first. ask your mechanic about where to get it done.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 03:11 PM   #3
mcflux
mcflux's Avatar
As far as I'm aware swapping the box shouldn't impact on the speedo readouts? Did you put the speedo gear from your auto into the T5?
Old 20-10-2006, 03:47 PM   #4
poomba
xc - my other love
poomba's Avatar
perhaps the jacar speedo kit, but that is really designed for cars with different diff gears... did u change diffs too?
Power = Money
How fa$t you wanna go??
apparently pretty fast - 400rwkw BF xr6t!
FG F6 bottom end - GTX3582 - Nizpro 4" exhaust - Nizpro cooler - plazmaman intake - piping - plenum - batt relocation - injectors - surge &044 pump - valve work & valve springs - XCAL
poomba is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 09:30 PM   #5
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
no the diff wasnt changed and i put the speed sender from the auto in this gearbox but its off and i dont know why, im stumped
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 20-10-2006, 09:35 PM   #6
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Umm,
What diff ratio do you have?
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 09:45 PM   #7
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
i have a 3.27 so im using the green gear
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 20-10-2006, 11:58 PM   #8
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
could it be my wiering, or is it time for a new cluster
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 21-10-2006, 12:37 PM   #9
smally289
growing up is optional
smally289's Avatar
Keep the same speedo transducer, just change the gear. You need to speed the speedo up, so change the gear to one with less teeth. There is a number on the end of the gear (19, 20, 21 eg). I would go for a 2 tooth change and see how it goes.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2006, 02:58 PM   #10
Rollin
Rollin's Avatar
If you changed the transducer from the auto to the manual your speedo should read the same...but if thats not the case then probably do as smally351 suggested.
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2006, 08:14 PM   #11
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
its green now should i choose a black one
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 22-10-2006, 11:44 PM   #12
smally289
smally289's Avatar
how many teeth on the one you have now?
Old 23-10-2006, 12:04 AM   #13
Christiaan
Christiaan's Avatar
black = 3.45 ratio.
Old 24-10-2006, 02:41 AM   #14
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
well i havent changed the diff tryed 3 drfferent speed sencers and the wiering was done by a pro so im lost, where can i get a digital cluster and get it set to the same km's
VE SS Ute manual 09
125 Thumpster 2010
Swag
