Old 25-10-2006, 09:02 AM   #1
NZL10971
Question Noise under braking
Hi Team....
Had a few noises and groans from the AU in the past but nothing like this, this time the mechanic shrugged his shoulders so any advice appreciated...
We were out and about the other day in country and I was finding that coming down a windy hill and braking into a left hander I would get a clunking noise from the left hand front wheel or side and I swear I could feel it translating thru the brake pedal... am going to another mechanic but thought I would ask you all knowing ones first, if anyone has had similar ( bearing done recently too )
KIWI ( novice when it comes to repairs )
NZL10971 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 01:24 PM   #2
bodes-sh
welcome to the forums.
i did get that until i replaced the factory rotors and pads with rda slotted rotors and rda pads, i don't get it anymore, sorry i can't shed anymore light on it, oh by the way mine is an au1 forte...
Old 25-10-2006, 02:50 PM   #3
str02
99 AU Futura
str02's Avatar
Thats sounds like a good place to start, was it done by the same mechanic? Get another opinion
I am not young enough to know everything
str02 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 08:11 PM   #4
Baboon_AU
Baboon_AU's Avatar
ball joints mate... i would check them next
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2006, 08:36 AM   #5
NZL10971
Ball joints...?? is this something I could spot myself as the mechanics locally are just zero help at this stage, and it's a huge hassle to keep going back to them... a pointer in the right direction would be a huge help...
Old 26-10-2006, 08:36 PM   #6
bodes-sh
afaik ball joints need to be pressed out/in, so unless you can get access to a pressing machine i'd say not
Old 27-10-2006, 02:08 AM   #7
blackers10
blackers10's Avatar
jack the car up.. get a mate to help
one of you wiggle the wheel(as in wheel and tyre not steering wheel)
up and down.. then side to side
this will also reveal any tie rod issues or wheel bearings etc
the ball joint looks to require pressing out (just looked at a photo of mine)
Old 27-10-2006, 10:04 AM   #8
ronwest
All Bran = Regular Member
Jeez guys, a simple google for "remove ball joints" will show exactly what is required.
eg:http://www.extremehowto.com/xh/artic...ticle_id=60227
It's great that you want to help but it really doesn't take much to pass on accurate info...
Old 27-10-2006, 12:01 PM   #9
NZL10971
Cheers to all of you that replied... and "ronwest" what a great link you put up very informative, will let you know what we find
KIWI
Old 27-10-2006, 05:47 PM   #10
scuwp
2004 TS Territory
scuwp's Avatar
Yeah I have to agree. I got the lower balljoints in mine replaced with the same "clunking" problem. Problem solved although it was $200 bucks later. My understanding is that they need to be pressed into place so you need the right gear. Also get the mechanic (or you if your that way inclined?) to ram a pile of grease inside the boot...it will help it last a bit longer next time.
scuwp is offline   Reply With Quote Multi-Quote with this Post
