Old 20-10-2006, 09:10 PM   #1
Jorgo85
Jorgo85's Avatar
Default Shifter: Solid or Rubber mount??
I'm currently looking at making a short shifter for my EF. I've taken the gear stick out and found a rubberized mount where it joins to the gear box. I was wondering what the pros and cons of having a solid mount (metal)..... :eclipsee_
Jorgo85 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 09:31 PM   #2
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Umm, underneath that shifter is a ballbearing type linkage that goes into the gearbox.
I can't see any advantage to a solid mount?
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 09:47 PM   #3
sphell
sphell's Avatar
I'm sure someone told me that solid mounting it is noisy....could be wrong though.
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2006, 02:36 AM   #4
DEVL-XR
EBII XR6
DEVL-XR's Avatar
^^sound like that could be true, you'd have to find out for sure tho.
EFXR65spd: when ya finish post pics and tell us how ya did it. i want to know!!
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2006, 02:02 PM   #5
Jorgo85
Jorgo85's Avatar
I've got 2 Type R 12" subs and 2 sets of Type R 6.5" splits to drown that out. Noise isn't an issue. What I'm worried about is breaking synchro's and ****. All I'll be doing is making a shorter gear stick (so it reduces throw) and putting a hand made billet aluminium knob on it. The rubber mount is on the bottom of the factory gear stick and has two bolts connecting it to the selector on the top of the box.
Old 21-10-2006, 02:16 PM   #6
Plunkett
never enough power
I just though it was there to reduce vibration from the box? The selector will still be mounted by the same 2 little bolts so I don't see how it would improve or hinder anything.
EA Fairmont Ghia sleep:
EA bottom end, AU tickford XR6 head JMM DEV 5, Race series headers, 5-speed manual, 3.7 LSD diff, sports suspension, sports brakes, all rapped up in a 89 champaign coloured falcon gl shell.
Plunkett is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2006, 02:55 PM   #7
Rollin
Rollin's Avatar
It will probably make your shifting more direct, but also more notchy and you will get more transmission noise up through the shifter, which you have said you dont care about.
Something I have noticed is that the rubber insulator you are talking about seems to differ between vehicles - I've driven some E-series where the shifter feels like the bolts are loose, even though I've just tightened them, and others which feel VERY direct...I suppose the amount of improvement you see will depend on if you are starting with a squishy insulator or a hard one...
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2006, 04:19 PM   #8
niko
likes falcon's
niko's Avatar
if you have ddecent rubbers you shouldnt notice a difference
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2006, 05:02 PM   #9
Kilma
Mine is a solid mounted BPT short stick. does the job. It is a bit louder than rubber mounts, but it feels so much more solid and I love it. I will see if I can find some pics where someone has done it as well.
2002 Suzuki GSXR1000: Yoshi pipe and cosmetic enhancements only. 10.7 1/4 mile
1995 EF XR8: Pacers, 3" all the way, stereo & Vortech V2=297rwhp, 13.5 @ 105mph 1/4 mile
Its not a TICKWUMP, its the TICKWUMP
Kilma is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2006, 06:06 PM   #10
SupahStah
Tha Stah
SupahStah's Avatar
Ive got a solid mount gear leaver...
Pros of Solid: Easier to find gates, easier to change, better for the 1/4mile, dont wear out.
Cons of solid: Noisier, rougher sliding in and out of gates (on the hands) no difference for the gear box itself.
Pros of Rubber: Smoother changes into gates, stock, quiet.
Cons of Rubber: They wear out, harder to find gates.
Well, thats my take on it... I perfer the solid heaps more, Though I did mention noisier, you dont notice it unless the car is off... I also have a shorter shifter.
Hope this has helped,
SupahStah
1998 EL XR6: |Custom POD Filter Intake, Pacemaker 4499's, Redback 2.5" Catback - straight through tail pipe.|. 113,000kms.
Best E/T: |15.080 @ 91.03mph | R/T: 0.848 | 60': 2.175 | 660': 9.674 |
Colour: |Regency Red.|.
Soon To Come: |Largish Cam + Chip|
ETA: *When the bank account is ready *
SupahStah is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2006, 08:47 PM   #11
Jorgo85
Jorgo85's Avatar
The new shifter is in the car. Just got a bit more polishing to do on the knob. Not that knob. BradensEBxr6, What I have done is taken a piece of 20mm dia. 316 stainless steel round bar(solid) and turned one end down to 10mm dia. about 50mm long and cut a M10 thread on it 30mm long. On the other end of the stick, I cut up the centre of the round bar about 40mm to create a flat surface to mount to the selector and I have put a small S bend in the stick. I can't tell you how long I cut the round bar because I didn't measure that. Was a "that looks about right" thingy. I will post some pics when I've finished "knob polishing" and I work out how to use photobucket
Old 24-10-2006, 08:58 PM   #12
Jorgo85
Jorgo85's Avatar
Also if you make your own, you'll need to replace the two bolts at the base of the stick because the factory ones don't have a long enough thread. When you replace them, make sure they're high tensile so they don't snap. High tensile bolts usually have 8.8 stamped on the head.
Old 25-10-2006, 12:39 PM   #13
EDXR65SPEED
I know a bloke who just removed his shift lever via the two bolts and cut the stick in half. Then put a thread on the end to screw the OEM knob back on. Looked good.
EDXR65SPEED is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2006, 07:49 AM   #14
SwarvJarv
Ea Falcon S
SwarvJarv's Avatar
Thats what im doin when i get my new gear stick...:
Jarv Smith
88' Ea Falcon S
3.9MPFI
5 speed Manual
Motivator Headers with 2.1/2" RedBack system
XR x GT Hybrid Body
15" 'Snowflakes'
90' GL Interior
Custom Black Vinyl Roof
Custom Console Lid
9" LCD + PS2
Boss CD/MP3 head unit 50x4w
Originally Posted by Rmyers
I was considering chucking on a full Kappa tracksuit but reconsidered :P
SwarvJarv is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2006, 07:53 AM   #15
niko
likes falcon's
niko's Avatar
but that's just literally shorter, with the same strokes.
Old 28-10-2006, 08:46 PM   #16
Jorgo85
Jorgo85's Avatar
Shorter stick means shorter strokes. It all pivots from one point. The longer the stick, the longer the radius, the longer the throw.
Old 28-10-2006, 09:49 PM   #17
efgiar
rofl copter
efgiar's Avatar
that rubber is to stop vibration on the stick from the gearbox, its a crap load better if u take it out and run the stick solidly mounted to the box
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
