Old 08-11-2006, 11:16 PM   #1
[Tonko]
What's green is gold
[Tonko]'s Avatar
Default I think its a bit broken
after complaining about shuddering steering on the old mans EL ghia 5.0 i decided to have a bit of a looksee first the tyres were scrubbed right down to the canvas... she'll be right he says,
but im glad i got to it before disaster struck.
i couldnt believe after just clicking over to 100,000k's the steering rack is already gone,
Thats exactly how it looked when it come out too, except there were heaps of rubber shavings all over the place...
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 08:44 AM   #2
EA2BA
PM me if you want
EA2BA's Avatar
looks like some missing washers caused the problem.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 10:17 AM   #3
OLDFORDNUT
OLDFORDNUT's Avatar
this is the reason i dont trust anything but real rubber.
Hervey Bay QLD
Great trades recently- GILMORE
BOSSYONBIKE
OLDFORDNUT is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 11:44 AM   #4
Tiga_EL
Tiga_EL's Avatar
Isnt nolathane supposed to be better than the rubber though?
Tiga_EL is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 11:55 AM   #5
Sundeep
Sundeep's Avatar
It's stiffer so instead of wearing out it'll just break or split.
That's not the steering rack though, that looks like the k-frame side of the lower control arm.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 12:24 PM   #6
OLDFORDNUT
OLDFORDNUT's Avatar
nolathane wears out just as quick in 4x4 springhangersas rubber if not faster
Hervey Bay QLD
BOSSYONBIKE
Old 09-11-2006, 02:53 PM   #7
arm79
arm79's Avatar
What you have there would be about right for the KM and a Tickford suspended car.
I and 3 other guys with Ticky suspension have already had this happen, but we were talking KM ranges between 120,000 and 170,000. And I'm sure your old man would have complained about really floaty steering and tires that would squeal like crazy, which would be the first indicator of the problem.
Being a urethane compound, it will require some maintenance. The maintenance being a regular greasing of the inner bore of the bush. As we know, the bush pivots on the pin (unlike the rubber versions) and if there isnt any grease, the bush will quickly deteriorate, like you have seen.
It is mainly compounded by the problem that from the factory they put very little to no grease on the bush.
When I replaced mine, I put in a reasonable amount of grease, and when I took the arm out about 13,000km later to check them, they were like brand new. The bush was as stiff as it was brand new, and the inner bore looked brand new. Still had the cross cross patten on the bore. So I regreased them and put them back in. Sadly shortly later the car was written off, but when I got the car home and took the bush out, it was still perfect. These are for sale now if you're interested. <-- Inserted shameless plug here. They arent a cheap replacement.
While some people prefer the rubber bushes, even if I spend a couple of hours a every 5/6 months greasing these bushes, its a fair trade off for the better handing they offer than the rubber equivalents.
Old 09-11-2006, 03:51 PM   #8
BI6TIM
SnortPerformance.com
Urethane bushing has proven itself useless in the 'lower inner' position on EF/EL time and time again. To the point that, when I left Pedders, they wouldn't sell urethane bushes for that aplication, rubber only. The rubber one are easily lasting a minimum of two years without customer complaint or adversly afecting wheel alignments.
Although I am all for Poly Urethane bushes correctly placed, I would warn anyone off using them for the 'lower inner' on EF/EL.
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 04:03 PM   #9
arm79
arm79's Avatar
That would be a big call considering there was zero problems with my vehicle (and many others with urethane) for the first 3 to 4 years of its life, with no affects to wheel alignments in that time. The failures happened quickly (within 8 weeks) from first noticing until the car being undriveable.
I think we should all realise that urethane bushes require manitenance during their life, and that rubber doesn't. Now that I know regreasing is required, I will make it happen reguarly.
Old 09-11-2006, 04:41 PM   #10
XRated
Shoot.
XRated's Avatar
BI6TIM, is there any chance you could give us a list of where you recommend rubber, and where you recommend urethane on EB/ED EF/EL by any chance?
I don't fancy having to remember to "grease" bushes every 6-12 months.
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 08:23 PM   #11
futura97
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
i'd personally only use urethane bushes for the swaybar d's and links.
Rubber everywhere else...
futura97 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2006, 12:56 AM   #12
fmc351
let it burn
I second this request. :lookedat:
fmc351 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2006, 10:02 PM   #13
futura97
I think bi6tim will same the same as me....
Old 10-11-2006, 10:03 PM   #14
futura97
or though.... the urethane aftermarket lower inners for the ef/el are heaps better than the tickford ones... as long as they are greased properly you will have no dramas
Old 10-11-2006, 10:37 PM   #15
[Tonko]
[Tonko]'s Avatar
i think its happened before, because one bush was rubber and the other (this one) was Nolathane, now to fix the power steering rack...
