Old 18-11-2006, 05:00 PM   #1
slickef
Apprentice Fridgey
slickef's Avatar
Location: In a lil place called Gladstone aka. Glad2bstoned
Default Control Valves removed?
Has anyone with an ef/el or higher removed the control valves in the intake plenum?? I have been told that if removed they increase flow but take away the torque down low? Supposed to be a good mod!
96 EF Falcon Futura, Powered by Microtech, 2222549 Crow Cam, Metal Gasket, Port and Polish, Oversized Forged Valves, EF Fairmont Dash, K&N Highflow Filter, Pacemaker Competition Extractors, 2 1/2 Mandrel Bent Exhaust, High Flow Cat, Converter Shop 3500 stall, Shift Kit, 4.11 Diff Ratio, Mini Spool
Best ET 14.654 @ 88.270Mph at Benaraby Raceway, Gladstone Queensland
slickef is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2006, 08:22 PM   #2
Holbrookau
OPT 20
Holbrookau's Avatar
Very little (if any) to be gained up top and you will loose low end torque. With a modded engine you may gain something by changing the point at which the valve opens - you would need advice from those who have done and proven so though. The stock BBM system is actually quite good.
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Holbrookau is offline   Reply With Quote Multi-Quote with this Post
