#31 | ||
Yeah pretty nicely done huh? Couldn't have hit a gutter better myself if I tried I reckon.
Yay for finding urethane bushes in the control arm, boo for the control arm going in the bin. Sundeep |
#32 | ||
Tuned @ Pitlane Frankston
****. That would have hit at atleast 70 kays.
#33 | |||
this is true
Right on the money really good impact, not good for the back a little bit of whiplash up the gutter at about that speed to do that damage.
EF Fairmont, stage 2 crow cam, 18" apache rims,xr air intake,full Lukey exhaust system, supalow springs, green dash mod,last dyno 145rwkw,stereo :gren: |
#34 | ||
V8 Ute V8 Boat
the question every one wants to know the answer to, how is the gutter?
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
#35 | |||
![]() Join Date: Jan 2005
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
#36 | ||
ma\\\
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
#37 | ||
Rocket Fuel Anyone?
been there done that. He probably needs some new stabilizing bars too. When I did it I bend my rear axle as well.
#38 | ||
the gutter was fine. The people who slept in it were not so lucky.
#39 | ||
Lol you guys still going?
The car is fixed, didn't take so long to do it. I hate working on suspension but I'm such a pro I could replace the whole front end in 15 minutes with 2 people helping. Anyways.. everything lined up well and the car drives nicely. Just needs a wheel alignment and it's set. Replacing the distributor, on the other hand, was a whole other story :'( Sundeep |
#40 | ||
can you sign my rocker cover sunny ?
#41 | ||
Man I'm gunna bring the fattest **** off texta to the next cruise and make sure I sign you rocker cover.. if you don't let me I'll drop ya..
Sundeep |
#42 | ||
I can't believe you are whinging about replacing the distributor! so easy!
take off airbox lid and IAC motor, take off plug leads at plug ends and remove cap, pull it all out. remove the rotor and the other plastic bit the cap sits on, undo the bolt that holds the dizzy in and pull it out carefully.... d@mn mexicans... |
