03-12-2006, 08:27 PM | #1 | ||
The 'Stihl' Man
Ok well, after the cruise today I picked up some JMM Streetfighters.
I want to have a crack at installing them myself (or with a little help, we will see). Is there anything else I need to buy? Is there a gasket? Some people said something about glue aswell (I assume gasket glue). Also, there is some surface rust spots that I will sand off, I was thinking of spraying it black to keep the stock look. Ill use some paint that can handle the temp, (VHT), there shouldn't be any draw backs to this I assume? People can paint there coolers and pipes black, so I thought that it shouldn't effect the extractors. Any clues? Cheers!
03-12-2006, 08:58 PM | #2 | ||
PM me if you want
Generally you have to get the cat cut down and a flange welded on for a start.
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
03-12-2006, 09:00 PM | #3 | ||
The 'Stihl' Man
Yeah dont worry about that stuff, thats for the pro's, I just want to concentrate on getting them on first.
I will then take it to a shop and they can deal with the cat and 2.5' cat back.
03-12-2006, 09:25 PM | #4 | ||
Riding The Lightning
you gonna drive to a exhaust joint with just extractors on and nothing on the end of them
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA |
03-12-2006, 09:40 PM | #5 | |||
The 'Stihl' Man
: Anyways, well the paint be ok? Anything else I should keep in mind when doing it?
03-12-2006, 09:46 PM | #6 | ||
wear earmuffs maybe, cause its gonna be ****en loud, and the floor under your feet will vibrate like a ***** as well, should be alright for 5 mins though might get a bit of smoke coming from under the car as well
03-12-2006, 10:04 PM | #7 | ||
V8 Ute V8 Boat
i payed $50 to get them to take my old ones off and put my extractors on and weld up my car too and dump the old manafold
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
03-12-2006, 10:15 PM | #8 | ||
The 'Stihl' Man
Well the only reason I am doing it myself is because the place that I am getting the 2.5 cat back done said that they woudl charge me $150 just to fit the extractors.
Which would then negate the whole point of me buying them in the first place, I was quoted $450 for the pacey's, but I wanted these.
03-12-2006, 10:17 PM | #9 | ||
Might be easier and cheaper to install the extractors, measure up the required length of the cat and take it down to them to cut and weld to size.
04-12-2006, 12:20 AM | #10 | ||
What's green is gold
good old extractors, they are easy compared to the ones i just did to my car, pacemaker 4 into 1's onto a 351 XD, loosen engine mounts, undo the right one, jack the car right up, jack the motor on the angle, put first piece on, put second one on, then reverse procedure, the left one goes on in about 5 minutes...
plus i have to drive it into town (10k's) with just the extractors because my exaust is buggered, good luck anyway, it makes a big difference, sounds awesome too!
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
04-12-2006, 06:49 PM | #11 | |||
Ea Falcon S
i drove my EA for 5-6 months with just extractors (tri-y) and the collector gasket flange.......:..bloody fange weld snapped in the cat...
sounded mad.....
Jarv Smith 88' Ea Falcon S 3.9MPFI 5 speed Manual Motivator Headers with 2.1/2" RedBack system XR x GT Hybrid Body 15" 'Snowflakes' 90' GL Interior Custom Black Vinyl Roof Custom Console Lid 9" LCD + PS2 Boss CD/MP3 head unit 50x4w Quote:
04-12-2006, 08:04 PM | #12 | ||
eec tweaker
catbacks can be had for $150. theyre very simple to fit. fit the extractors yourself (youre already on it). drive it down to get the CAT welded up... make sure you get 2.5" ends put on it (or a 2.5" cat).
wallah. |
04-12-2006, 09:10 PM | #13 | ||
The 'Stihl' Man
well I picked up some sandpaper and paint today, will do that tomorrow and then try and fit it wednesday/thursday. Then take it to the shop friday, should be sweet!
04-12-2006, 10:05 PM | #14 | |||
Then again Josh's (efgiar's) car sounded awesome at Heathcote when he ran the exhaust straight out of the manifold :P |
04-12-2006, 10:09 PM | #15 | |||
