Old 02-04-2005, 11:25 PM   #1
EA Turbo Ghia
Motor breaker
Default Clevo into EA
I'm just about to start putting a 351 clevo with C10 into my EA, due to prematurely destroying an auto, is there any structural problems with this that anyone knows of?
EA Turbo Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2005, 12:02 AM   #2
Sundeep
Sundeep's Avatar
What are you doing with your turbo stuff?
Sorry I can't help with your question, but I have to ask!
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2005, 12:25 AM   #3
BJ
The first thing is do you expect to get it past the engineers? The reason that i ask is because i have had the same projet on hold because they would not even think of letting it through. It is still sitting in my old work shop. The main things where chassis strength plus brakes and steering geo.Getting the thing to fit is fun and to wire it up is no problem its jut bloody vic roads that are a pain in the asrs.
BJ is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2005, 01:08 AM   #4
blackers10
blackers10's Avatar
well what is hte difference in chassis or chassis strength between a EA and a EB/ED XR8??
im also interested to know how if the V8 outta those cars or the NC fairlanes will fit into my NA fairlane and if it would pass engineering...
im in QLD btw..
i emailed ford the question and they emailed back with an automated response that basically said... go see a dealership
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2005, 01:14 AM   #5
old_mate
Smash the Boost
old_mate's Avatar
I have only seen one EA with clevo on the street, and it was straight LPG for emissions. Used EL GT brakes etc. Is waaaaay easier to buy a EB with a windsor and stroke that.
EA actually had quite a bit less chassis strength than EB onward. The only way I can see getting a 351 into a E series car would be using a 351 injected windsor out of an F truck. Its a pain getting a older engine into a newer car legally
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2005, 11:13 AM   #6
BJ
im in QLD btw..
THe diference between the two in weight is about 150 lbs withc when put over the front end make a lot of difference i can tell you. That is the reson they quote the chassis strengh. And also the space between the strut towers is at a best a real tight fit.
Old 03-04-2005, 11:22 AM   #7
svo347
AFF's 1st DM.......
svo347's Avatar
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
You can fit a 51 Clevo into an EB, theres a guy who did it with a Blue EB been featured in alot of mags.. And its a daily driver!!
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2005, 11:37 AM   #8
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
im in QLD btw..
Yes a 302W from an EB-AU/NC-NU will fit straight in, although you will need to convert back to a distributor if you get an AU motor.
EDIT - I'm not sure about the rules in your state, you need to ring the DOT in your state. In SA you dont need to have an inspection to change the engine over to a V8 from a 6 in an EF, as the K-frame, brakes, suspension etc is all the same.
DO you mean the weight difference between a 351C and 351W or the difference between a 6cyl EA and a V8 EB??
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2005, 11:44 AM   #9
Racecraft
they call me Tibbo
Racecraft's Avatar
I did it but got stuck trying to get the headers thru engineering as it was thought they would foul the lower steering shaft. I could of redesigned them but after all the effort I put into getting it to that stage I was kind of deflated. The biggest issue i had was due to the fact that I moved the engine back 2" to improve weight distribution and not use a lenghtened tailshaft
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2005, 11:59 AM   #10
neil101
The EB you speak of is now bright yellow with a supercharger hanging out the bonnet and runs on strait gas. Passed it in NSW I thought we were the hardest state to get a car passed.
Neil
HSV I JUST BEAT ONE!
03 XR6T lighting strike auto prem sound 19's
383.9rwkw
96 EF series 2 XR8 sedan manual
neil101 is offline   Reply With Quote Multi-Quote with this Post
