Old 07-12-2006, 10:23 PM   #1
needaXYGT
AU II XR8
needaXYGT's Avatar
Default AU Headlight adjustment
We have an AUII at our place with headlights that need focusing. The vertical adjustment is not a problem as the orange knob at the rear of the headlight assembly is easily accessable. However the horizontal adjustment doesn't appear to be quite so easy.
There are some white knobs on the outer/upper portion of the headlight assembly located at the rear of the unit with serated edges. These are hiding between the assembly and part of the subframe. I'm assuming the serated edge of the knob allows one to manipulate and focus the unit by turning the said knob with a screwdriver (if in fact it's the correct knob/adjuster). They're not all that easy to get at and seem rather fiddly and difficult to turn and adjust.
Hoping someone out there might be able to suggest a method of adjustment that isn't quite so painful and tedius. Thanks.
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 10:54 PM   #2
HLC
Audi S3
just loosen the bolts that hold the headlight in place and physically move the whole unit and then tighten it up again... thats what i did.
Old 09-12-2006, 10:20 AM   #3
str02
99 AU Futura
str02's Avatar
Yep they are the adjusters, just need to angle a phillips head screwdriver thru a hole on the sill next to battery on right and similar position on left and turn the screw which then turns the white gears you have seen. I have some close pics if you need
I am not young enough to know everything
str02 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2006, 06:59 PM   #4
needaXYGT
AU II XR8
needaXYGT's Avatar
thanks, ill give it a go ;)
