Old 27-03-2005, 02:12 PM   #1
need psi
slow & low EA Ghia
need psi's Avatar
Default help! no dash lights
hey guys on the way home last night i done a huge compression lock up and the entire car bounced around and shook everything. the car is an ea fairmont ghia. the dash all works including speedo but no interior lights work except for the speedo back light. so at night i cant see my tacho or temp guage but can see the speedo. would i have just blown a fuse or shook the earth point or something else? is there an earth point for all that? any help on what it would be is appreciated.
Ehab
Ea Fairmont Ghia 1988
need psi is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2005, 02:54 PM   #2
danege
danege's Avatar
There is an interior light fuse, so check that.
1994 EF XR6
danege is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 10:26 AM   #3
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
I doubt the fuse has blown if the speedo light's still working. Have you checked to see if the globes are blown?
I see the 5 speed's getting driven 'sensibly'........
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 10:42 AM   #4
MissUnderstood
I see dead people.
MissUnderstood is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 12:16 PM   #5
LUXO_8
windsor user
from my understanding of the digital dash, the dash lights are seperate from the digi cluster's backlighting.
id still check ya fuse mate...
Old 28-03-2005, 12:30 PM   #6
AUII_Forte
AUII_Forte's Avatar
Deffinately interior light fuse.
2003 Narooma Blue BA XR6 5spd Manual.
Pacemaker 4490 Extractors
2.5" Exhaust
High Flow Cat
SS Inductions "Growler" CAI
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
AUII_Forte is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 02:38 PM   #7
Walkinshaw
Two > One
Walkinshaw's Avatar
Ehab
BWHAHHAHAHHAHAHHAH that was the 2nd funniest part of that night!!!!!
Your tail lights went out as well!
We should have video of this soon.
1978 LTD - 408ci - 11.5@120.6mph -
2004 S4 - 4.2 - M6 - quattro -
Walkinshaw is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 02:39 PM   #8
MightyXR6Turbo
Boooostn'
MightyXR6Turbo's Avatar
i see the funniest compression lock ever... and its on film ;)
haha yeah thats right, the tail lights died after that too lol
MightyXR6Turbo is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 05:10 PM   #9
JADED6
V8 Ghia & BF2 XR6 + Wagon
JADED6's Avatar
Must have been pretty nasty Ehab. I give your head gasket 6 months.
If the tail lights died, check fuses. Or maybe you shook all the globes out of the back of the cluster and rear
Must have felt good, we have a manual forklift at work that gets locked up all the time.
Windsor now harmonically balanced for EARTHQUAKE free driving!:
JADED6 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2005, 01:27 AM   #10
montyv8
Turbo Dinosaur FTMFW
montyv8's Avatar
wasn't "compression lockup", it was suddenly realising that the lights were red....
your brakelights don't come on when you 'compression lockup".
or you have soft legs that can't handle the 'Xtreme' clutch lol ;)
1973 XB Fairmont Coupe, turbo EFI SBF
8.23@168MPH
montyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2005, 07:34 PM   #11
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
tail lights are generally on the parker fuse along with dash lights
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2005, 11:04 PM   #12
need psi
slow & low EA Ghia
need psi's Avatar
the problem was a wire behind the deck had come loose so it wasnt earthed at all.
phil - while gearing down when coming up to lights usually you brake! i think thats why it was so big, my legs are soft i only weigh 40kgs these days.
has anyone got the vid as an mpeg?
Jade 6 - blew the motor last tuesday going up the express way. filled up oil in the bitch and used 4.5litres of oil and 4litres of water from mount lofty turn off to northfield!
so au conversion is coming up soon. with the possible help of phil?
