Old 10-12-2006, 10:45 AM   #1
naughts
Hmmmmm Mulberry....
naughts's Avatar
Default AU2 Auto Tranny cooler. Picture please
Well, Did a bit of towing yesterday and boiled the auto tranny oil. . Hopefully the tranny is o.k.
Anyway, Who runs a tranny cooler and could you post a pic if it so I can see where to mount one, how big they are, etc.
Thanks
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2006, 11:38 AM   #2
Mechan1k
Mechan1k's Avatar
I mounted mine on the driver's side near the bottom of the A/C condensor.
Hard to take pics though ... you can barely see it unless your are down on your hands and knees.
I had a pic somewhere on the PWR cooler I got (actually got the V8 version on my I6).
Old 10-12-2006, 11:40 AM   #3
Bill M
Bill M's Avatar
Default AUII XR6 trans cooler pics
G'day naughts, here is a pic of mine just after installation. It is a PWR type 250mm x 280mm wide and about 20mm thick. I have not yet plumbed it into the transmission lines yet, no time! It is the model that can run with the radiator or bypass. I did not have to remove the bumper only the black undershield underneath the bumper. I think this is the same type as Mechan1k used with success.
cheers
Bill.
AUII XR6 VCT ute
20 years and still going strong!
Bill M is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2006, 11:41 AM   #4
Mechan1k
Mechan1k's Avatar
Yeah ... looks like mine
Old 10-12-2006, 01:07 PM   #5
nikos
mezzo forte
my baby radiator is mounted just in front of the engine one, down behind the front scoop (au1 forte)
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2006, 02:13 PM   #6
naughts
Hmmmmm Mulberry....
naughts's Avatar
Do you still run it thru the radiator or bypass the radiator?????
Old 10-12-2006, 08:46 PM   #7
private9
www.TUFFCARPARTS.com
private9's Avatar
You can either run it in line with the radiator or bypass it altogether. Most people will reccomend that you bypass as the transmission cooler in the radiator can fall apart over time and let coolant through your tranny - not good!
I bypassed mine.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2006, 09:48 PM   #8
Cam
Stroking it...
Cam's Avatar
well my front bar is off undergoing some repairs after a run in with a maccas speed bump, so i went and took a picca for ya...
http://fastfords.org/pics/camspics/30-08-06_2030.jpg
Mine sits smack bang in the middle, i need all the cool air i can for a "stockish" auto behind a 347..
Cam
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2006, 12:27 PM   #9
xr8 007
xr8 007's Avatar
Is it possible to have a "HOW TO" write up on how to fit these tranny coolers as its a very hot topic, aslo i just purcahsed one and need some info ehehehhe
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2006, 01:36 PM   #10
blackers10
blackers10's Avatar
my uncle was suggesting that it would be better to run with thru the radiator.. as when in heavy traffic / stopped there is NO airflow over the trannycooler if it is external to the radiator..
where as if it is inside the radiator it will have heat pulled from it via the water flowing thru the radiator because of the water pump??
any ideas on this?
Old 12-12-2006, 06:24 PM   #11
bodes-sh
^^i would think the thermo fans would help more in heavy traffic than just the water being pumped around, if you bypassed the radiator the thermos should still provide enough airflow to keep the fluid fairly cool...besides if your not moving it's not going to be heating up unless you are stalling up the car
