Old 14-12-2006, 01:41 PM   #1
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
Exclamation Bent Axel
hey guys.
discovered last weekend that i have a bent axel on the rear passenger side. i have no idea how it happened but i now need it fixed.
does anyone know a good price for a second hand axel?
would anyone be willing to lend a hand doin it? i have never done the job before. i live in lara. 15 km's out of geelong....... :Reverend:
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 01:43 PM   #2
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
im willing to pay with beer or money, im easy.....
Old 14-12-2006, 01:45 PM   #3
mcflux
mcflux's Avatar
sechs?
Old 14-12-2006, 01:48 PM   #4
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
sorry?, lol
Old 14-12-2006, 01:53 PM   #5
mcflux
mcflux's Avatar
nah forget it :P (I'll wait for others to read and laugh (at me?))
No idea about axles on their own but I'm sure you could pick up a 2nd hand diff (make sure it has 28 spline axles) for very cheap and pluck the axle from that.
Old 14-12-2006, 01:55 PM   #6
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
im assuming u meant s e x?
Old 14-12-2006, 01:58 PM   #7
-jjM-
-jjM-'s Avatar
Originally Posted by Ghia5L
sechs?
lol dirty *****
-jjM- is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 02:04 PM   #8
mcflux
mcflux's Avatar
don't worry, unlike your axle (and jjM) I'm straight
just bored at work
Old 14-12-2006, 02:25 PM   #9
Dezza
Parts bin special
Dezza's Avatar
just bored at work
LMAO D4V3. You must be bored!
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 02:50 PM   #10
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
so can anyone actually help with my axel??
Old 14-12-2006, 03:09 PM   #11
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
i can run you throught it
jack car
remove wheel
on the disk there is a phileps head screw, undo it
take the breaks off
pull the rotor off
there are 4 bolts that hold the diff and the axel berings on undo them,
pull the axel out
put new axel in
then do it all up together
its not overly hard takes around 2 houres if you havent done it before, but its not difficult
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 03:10 PM   #12
castek
i had a bent axle (and just about every arm underneath as well) i picked up a single spinner diff out of a ef with 140k's for $80 disc to disc. its a fairly easy job as everything just falls out once u undo all the bolts.
castek is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 03:12 PM   #13
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
i think the place in vic is called pick a part, go there and pull the axel out from a ED and u will know how to do yours when u go to do it and u dont brake your car and u learn somthing,
do i get the beer now
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 14-12-2006, 03:15 PM   #14
RG
Back to Le Frenchy
RG's Avatar
It's easy to do, I have an EL diff here for $50 if you want it. Just so happens that I thought I had a bent axle in it (passenger side) so I got it all checked out and cleaned up good as new with a new bearing, it's done about 5,000k since that was done. Let me know. Also you will need a big phillips head screw driver as the screw tends to be a right ***** to get undone if it hasn't been taken out for a long time.
Old 14-12-2006, 03:19 PM   #15
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
for the screw driver i put mine on a grinder to fit probely so i could get it undone also rp7 helps if you spray it and leave it for a few mins
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 14-12-2006, 03:21 PM   #16
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
ok guys. i'll have a go myself. hopefully i havent bent anything other than the axel.
REDXR8220, i mite need to buy that diff from ya. ill pm ya if i do. thanks guys
Old 14-12-2006, 03:25 PM   #17
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
if you fly me to you and home again i will do it for you and colect my beer,
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 14-12-2006, 03:44 PM   #18
[Tonko]
What's green is gold
[Tonko]'s Avatar
sechs?
BWAHAHAHAHA... :
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 04:02 PM   #19
oneredED
need more boost
oneredED's Avatar
When I bent my RH axle, I had quite alot of trouble getting it out (this is pre-spool btw) once everything was undone, and had to use a slide-hammer to get the bugger out. It took alot of effort, along with the bearing.
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 05:28 PM   #20
Gubas
- BOOYEH -
Gubas's Avatar
Clear your inbox John!!!
1993 EBII Fairmont Turbo T04e 7 psi
Gubas is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 05:50 PM   #21
NC_GHIA
FirstOnRaceDay
NC_GHIA's Avatar
I bent the same one I paid $40 bucks for One on the EA...
MY BRAND NEW RIDE
NC Fairlane GHIA
Series II
I6.
Mods. 2.5" cat back
Clarion HU
Soundstream speakers amp and subs
Lowered
DL LTD rims
: thats it!
For the moment... :
NC_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 10:32 PM   #22
trick_xd
I build your wish list...
trick_xd's Avatar
Soooooooo many things going wrong with your car John ..
Burn it ---- hahahahaha
narr doing a axle is easy .. take you all of 90min if your slow......
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2006, 11:51 PM   #23
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
hahaha, i swear i should just up my insurance cover and burn it, lol
Old 15-12-2006, 10:23 AM   #24
castek
took me and my old man, both without any experience 3 hours to change the diff, arms, bushes, discs, basically everything on the rear end except springs and shocks. all for a cost of $310. incl diff. god i love cost price.
good luck with it all
