23-12-2006, 03:34 PM | #1 | ||
mezzo forte
Ive searched and searched and couldnt find the exact info on this.
How do i remove the top of the dash? im hoping to install tweeters under the little air vents, i dont want them in the a pillars. Can i remove the top of the dash without removing the centre console facia? Any help appreciated |
23-12-2006, 03:37 PM | #2 | ||
Its Resonating!
Dont think you can move the dash, centre console facia is the only way to get in there (I think)
23-12-2006, 04:07 PM | #3 | ||
BA GT-P Owner
Have a look through this section there should be somthing there to assist you
http://www.fordforums.com.au/photos/showgallery.php?cat=911 Cheers Mark
DAILY DRIVER/TRACK CAR BUILD NUMBER 006 299.5 rwkw's 12.74 @108mph ON MT's ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
23-12-2006, 04:25 PM | #4 | ||
mezzo forte
link doesnt let me in for some reason. thanks anyway
23-12-2006, 05:07 PM | #5 | ||
FTF Club Moderator
Whet vents are you talking about. The vents that face the mirrors on the outside of the car, the vents that face the windsheild or the vents that face you.
You can remove the very front of the dash where the aircon vents on to the windsheild. Couple of philips head screws. Though good luck getting the wires there without removing the whole dash. The vents that face your mirrows are just sitting really snug in the dash. As far as I can tell they just clip onto the dash.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
23-12-2006, 11:28 PM | #6 | |||
You can't stop the signal
Yeah, the vent covers just clip into the dash, don't know where you could wire from there though.
Personally i reckon putting them in the a pillers is the best bet. You can get the a piller from ford (think au and ba are the same) so that it looks all facotry standard(what i did). if you put them in the dash facing the windscreen, they're proberly gonna sound a bit harsh, cause the sound has to bounce of the dash. Just my two cents
24-12-2006, 01:37 PM | #7 | ||
mezzo forte
yeah i plan to use the mirror facing vents. if its that easy to pop them out, then i guess the trouble is still removing the dash to install the wiring.
how much of the dash do you have to remove to replace the a pillars? If its just the bit right at the windscreen edge, then i would consider that instead. Thanks for everyones help |
24-12-2006, 02:17 PM | #8 | |||
Right out sideways
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
24-12-2006, 02:59 PM | #9 | ||
BA GT-P Owner
The link was suppose to take you to the AU workshop manuals here on the forums.
26-12-2006, 09:47 AM | #10 | |||
Walking with God
Was it chief that posted a while ago that these a pillar trims are no longer stocked? He may have been talking about tweeters I think? Not sure. It could have been mechanik1 also. Not sure now. If the AU and BA bits are the same though, no worries! GK
26-12-2006, 02:21 PM | #11 | ||
FTF Club Moderator
AU a pillar trims are not stocked anymore as far as I belive (thats what I have been told by dealers and here on the forums). You can still use BA ute items though. The AU and BA A pillar didn't change.
To remove the a pillar, the dash does not need to be removed. Just simply take the rubber seal off the a pillar, grab the top corner of the pillar and pull. It will just unclip. Be careful when taking it out of the dash and there are little bits off plastic that guise where the pillar goes and you dont want to snap them off.
