Old 21-12-2006, 02:33 PM   #1
jonohall
Default tranny fluid change
hey guys
Could i please get info on changing the tranny fluid in an auto EL falcon. How to go about it and what fluid to use please?- photos would be great if available. Its getting a bit rough changing gears etc.
cheers
jonohall is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 05:14 PM   #2
poomba
xc - my other love
poomba's Avatar
ok, first a search wouldnt hurt on this but...
1: go buy tranny service supplies (1*filter, 1*gasket, 1*oil)
2: Jack car up and make sure IT IS SAFE, use stands or ramps, and chock the back wheel
3:undo all the pan nuts, crack them first, and loosen the back ones. you will have oils starting to dribble out (you can use an oil catch pan, or shower in it if you want)
4: once oil has slowed, remove pan and let the rest of the oil drain from the box
5: while this is happening, you will see a magnet on the pan you just removed. clean all the metal fillings off that.
6: while the oil is still drining, remove gasket from pan, and clean surface from any **** (goob, whatever) (feel free to eat the old gasket, you don't need it anymore)
7: Get your a*s back under the car and look at the filter in the transmission. if you don't know what one looks like, look at the one you just bought (One in the tranny may appear dirty)
8: note where the spring clip goes across the filter and mounts onto the castings of the transmission *Rember this*
9: remove spring clip, remove filter, wait for some more oil to drain (feel free to shower in it again)
10: replace with fresh filter and re insert clip (hold your tounge the right way for this)
11: put gasket on pan, and bolt pan back to transmission. be cearful that gaskt does not slip off its mount here, take your time and get it right. bolt up even and tight (not insanly tight, just firm)
12: check that gasket is as it should be
13: check it once more, then think, and check again (tranny oil is hard to clean off concrete)
14: let car off stands and put on level surface
15: pull out gearbox dipstick (drivers side, yellow knob right near firewall)
16: fill with tranny fluid down the hole the dipstick came out, be cearful not to over fill it, just do a bit at a time, using how much of the old stuff that came out as a basic guide. let it settle and check again, adjust where necessary.
17: take it for a drive, get it nice and hot (tranny may play around here, if it does, check the fluid levels and adjust.
18: get home and check for leaks and the likes
19: sit back and sink p1ss, with the self satisfaction on the fact that you yourself have just completed a transmission service... let the women come and the beer fall from the skies.
Power = Money
How fa$t you wanna go??
apparently pretty fast - 400rwkw BF xr6t!
FG F6 bottom end - GTX3582 - Nizpro 4" exhaust - Nizpro cooler - plazmaman intake - piping - plenum - batt relocation - injectors - surge &044 pump - valve work & valve springs - XCAL
poomba is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 06:13 PM   #3
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
what dammage can be done by over filling it, i have a manual but im interested
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 06:26 PM   #4
mcflux
mcflux's Avatar
well being an EL it may not have the dipstick like us earlier BTR drivers have.
Old 22-12-2006, 09:17 AM   #5
poomba
xc - my other love
poomba's Avatar
i doubt you wil see a dipstick on a manual, and its hard to overfill because it will just flow out the filler hole, but on an auto, i guess the dangers in over filling here: oil pressure?? burning fluid? fluid comming out the dipstick?? not sure, just made it good practise to do it right, and tranny fluid is expensive...
Power = Money
Old 22-12-2006, 09:28 AM   #6
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
haha i choose the second option! i need a shower.
ROFL
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 12:44 PM   #7
Bill_R
Bill_R's Avatar
just be aware that the method given by Poomba, while an excellent method, won't change all your fluid. To change it all you really need to flush the entire system or get it flushed. It cost me $200 to get a full power flush done (pumped 12 litres of all through before it started looking clear). The fluid was a very dark brown. Now I'm sure the fluid is (mostly) clean it will get a regular part change by me using the method given by Poomba.
Bill_R is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 10:47 PM   #8
there are cheaper and easier ways to flush the system see http://www.amsoil.com/faqs/ATF_and_F...Procedures.pdf
You should also adjust the bands after the fluid change.
Old 23-12-2006, 12:18 AM   #9
OED666
OED666's Avatar
the oil your after is TQ95...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2006, 12:20 AM   #10
penrith_panther
EB II
penrith_panther's Avatar
[QUOTE=poomba let the women come and the beer fall from the skies.[/QUOTE]
LMAO :hihi:
penrith_panther is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2006, 06:37 PM   #11
jonohall
thanks for the replies. being an EL it is going to be a little different. My gf got me the gregory's manual for chrissy. Ill read that thoroughly then get back to ya with questions i have!
cheers
Old 27-12-2006, 06:41 PM   #12
XR Martin
XR Martin's Avatar
Dont clean the oil pan with anything that has lint in it, as it can contaminate/block the various small oil galleries in the transmission.
Just rinse the pan in some petrol and put it back on, dont touch it ith a rag or anything.
2004 BA wagon RTV project.
Old 28-12-2006, 03:12 PM   #13
jonohall
http://cgi.ebay.com.au/Ford-EA-EB-EF...QQcmdZViewItem
ok value?
Old 28-12-2006, 03:52 PM   #14
brenx
brenx's Avatar
When I had mine done. I weighed up the hassle of changing the fluid and servicing the trans in my EL. I was lazy and paid $148 at the trans shop. The guy had a giggle about how black etc the fluid was. I told him the trans last service was @ 130,000k's. Done by Ford but I doubt they even changed it. I changed the radiator @ shofterly after 130,000 and the fluid was black then. Damn Ford dealer service! So the fluid had probably done 200k ;) The trans has 240k on it now and still works. Can't complain. I guess thats what happens when you don't let everyone get their dirty hands on your car.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2006, 12:39 PM   #15
hmc 'mont
ELMONTY
hmc 'mont's Avatar
i just did mine except screwed it.......... up however i went to repco and got the service kit (filter and gasket) for $30 and then another $35 for the trans fluid TQ95.
good luck
97 EL Fairmont - Regency Red
hmc 'mont is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2006, 04:20 PM   #16
jonohall
hmm yeah that one above is dear. found this one too. http://cgi.ebay.com.au/AUTOMATIC-TRA...QQcmdZViewItem
well if a seasoned falcon owner like u screwed it what hope do i have lololol. Ill still give it a shot...
Old 29-12-2006, 04:44 PM   #17
brenx
brenx's Avatar
Good ole ringwood auto parts. They are good
Old 29-12-2006, 05:01 PM   #18
jonohall
Thumbs up
yeah seen em mentioned a couple of times on the forum so did a search of their ebay store
