28-12-2006, 05:14 PM | #1 | ||
|AFordEd|
Hey I just want to knwo if anyone can tell me how to install a tacho RPM in my car?...thanks
29-12-2006, 02:49 AM | #2 | ||
ED4LYFE
Try the technical section. Or google it
giggity |
29-12-2006, 07:11 AM | #3 | ||
The one and only
Very easy as all the wires you need are there already.
I mounted mine on the steering column so the wires can run under the cluster. There will be 4 wires, pos, neg, light and tach. All easy
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
29-12-2006, 11:13 AM | #4 | ||
Wherever u go there u r
I put mine on the a pillar over the dash so its not in the way of the steering wheel at all, wiring is str8 forward and very easy,
Click to view full-sized image! Cheers
29-12-2006, 02:28 PM | #5 | ||
easy the wire that norm goes onto the coil you will find in you loom on the right side (passenger side there are two plugs, go to the main plg and you will find the brown wire from the loom splice into that wich is the coil wire it will save you the trouble of trying to hook it up onto the coil. the rest are your earth light power wires.
29-12-2006, 02:30 PM | #6 | ||
yep thats were i had mine but i moved the shift light to be near the pillar.
29-12-2006, 03:24 PM | #7 | ||
Girls! Drink! ****! ****!
First, check your transmission, if it's an Auto and your fitting a tacho with a shift light, then you're in trouble.
Automatic Driver and I'd be proud of that fact, only if I weren't so lazy. 1993 ED Fairmont Sedan - I6 - Colbalt Blue - XH Snorkel - Superlow Kings Springs and KYB Shocks - Cross Drilled and Slotted DBA front Discs - 18" pre-AU GT-P Alloy Wheels - Ford Original Bootlid Spoiler |
29-12-2006, 05:55 PM | #8 | |||
Tuned @ Pitlane Frankston
29-12-2006, 05:59 PM | #9 | |||
Almost as funny as the people that fit the fake cross drilled looking discs, with no cailper in sight, over drum brakes. Frickin priceless. Almost as funny as the Magna I once saw with a massive Cannon exhaust and hub caps.
