Old 30-12-2006, 02:53 PM   #31
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
EB GLi = no ABS = Cooler piping = Easier.
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 02:56 PM   #32
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
ohhh yeah!
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 02:58 PM   #33
DEVL-XR
EBII XR6
DEVL-XR's Avatar
damn you all!! nah i dont mind the ABS anyway! i'm thinking of running a pipe into the wheel arch but it'll have to be higher up and run down the inside of the wheel arch.
whats the legal side of cutting this area? engerneering, insurance, coppers etc.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 03:23 PM   #34
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
speak to a local engineer it is up to there discression. they are all diferent!
Old 30-12-2006, 03:36 PM   #35
DEVL-XR
EBII XR6
DEVL-XR's Avatar
fair enough!
DEVLXR
Old 30-12-2006, 05:22 PM   #36
ORSMEB
Steve
ORSMEB's Avatar
Originally Posted by ebmanul
...get a turbo and stop windging about hot air going in to your engine.
Lol! Shutup!
BTW, that looks like an EB engine in there...did the AU give in?
Silver PJ Ranger XLT
...with goodies...
ORSMEB is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 05:23 PM   #37
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
Originally Posted by ORSMEB
Lol! Shutup!
yeah the EB are sooooooooo much better, no turbo, pods all the way!!!! :evil3:
Old 30-12-2006, 10:57 PM   #38
ORSMEB
Steve
ORSMEB's Avatar
I thought you'd give up the turbo. You get about the same power from a pod, you just don't get the dose.
...with goodies...
Old 31-12-2006, 10:55 AM   #39
XR6xhute
Hi, I've found with my XH XR6 that the airbox with K&N filters went alot better so I've stuck with that, plus with the box you get the air coming in from the front of the bonnet, nice and cold.
XR6xhute is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 02:38 PM   #40
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
how do we find one?
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 03:28 PM   #41
XR6xhute
go on ebay, there are heaps of air boxes and things for it.
Old 31-12-2006, 04:12 PM   #42
angryboy
Braden i had the same basic setup as you except i had an aluminium heat shield made to support the pod and keep out the hot air, and i left the top of the box and binned the bottom half.Seemed to work well for a cheap setup and sounded good. Obviously it didnt keep out all the heat but it worked well
:sm_headba
angryboy is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 05:03 PM   #43
DEVL-XR
EBII XR6
DEVL-XR's Avatar
well all's i have to do now is get a fibreglass kit and fix up the holes around the intake pipe where i hacked into it! this will make it all smooth and neat! then i plan to get some more cold air into it via the wheel arch but that wont happen just yet.
DEVLXR
