Old 31-12-2006, 02:32 PM   #1
brother bob
Default swaybar adjusting
hey , just fitted a 30mm adjustable front swaybar does anyone know of the best setting for these as the whiteline site was a bit confusing on how to adjust .
cheers
brother bob is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 03:49 PM   #2
DNKPWR
DNKPWR's Avatar
Are you talking about the adjustable rear sway bars by whiteline??
If so i got it on the middle setting!
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
DNKPWR is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 03:56 PM   #3
brother bob
sorry i forgot to mention front sway bay . at the moment it is set to the front 3rd hole on both sides .
cheers
Old 31-12-2006, 03:58 PM   #4
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
cheers
i dunno mate...
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 04:31 PM   #5
ORSMEB
Steve
ORSMEB's Avatar
I've yet to install mine...so can't help sorry
Silver PJ Ranger XLT
...with goodies...
ORSMEB is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 04:40 PM   #6
gthofan
Gunna girlie-man
gthofan's Avatar
have you got the link to the given instructions?
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 05:27 PM   #7
efgiar
rofl copter
efgiar's Avatar
Originally Posted by CaRtZ
i dunno mate...
i dont know, i cant help you, this post is useless, +1
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 10:30 PM   #8
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
sorry i was pointing out that he did mention it was the front not the back bar like Dunky13 thought for some reason. was just tryin to clarify. i bolded it in the quote... then it wouldnt let me post a reply less than 5 characters.... my bad!
EF Wagon Project:
Old 01-01-2007, 04:51 PM   #9
sam12h
Runnin C3H8 & C4H10
sam12h's Avatar
To stiffen, you effectively make the bar shorter by using the holes closest to the rest of the bar (shorter flexes less).
To soften, you effectively lengthen the bar by selecting the holes closer to the end of the bar (longer flexes more).
http://www.whiteline.com.au/docs/ins...ar_general.pdf
The middle setting is almost the same as the 30mm non-adjustable (I emailed whiteline and asked a while ago). Don't go too stiff. You need stiff springs & stiffer shocks to match as well as control it, bumpy roads will be uncomfortable & difficult to stop straight & quickly on (the car will tend to go where it wants in an emergency stop) & it will understeer like a pig without a stiff rear bar setting to match.
http://www.whiteline.com.au/articles...-EFFalcona.htm
Production Editor- Street Fords, Xtreme Fords, Aussie Brutes and Custom Utes Magazines
sam@streetfords.com
Phone: (02) 9741 3838 (direct line)
sam12h is offline   Reply With Quote Multi-Quote with this Post
