29-01-2007, 09:28 PM | #1 | ||
So this year I am going to start properly doing things to my car on my list are shaved door handles, manual conversion and maybe LSD and possibly cam.
My questions are, 1) I want to fit an ef/el gear box because apparently they are stonger and nicer to drive, is this true or should I just go a eb-ed box?(I dont want an ea box). 2) If I do put an ef/el box in does the ef/el ecu have to go in aswell(I dont want to do that resistor mod thingo) or would a manual eb-ed ecu do the job and is that the only thing different between that and an eb-ed box like does it still plug into that plug under the car? 3) Would my wagon tailshaft fit the ef/el box? 4) with diff gears, can my single spinner diff be converted to LSD with different gears or is it better to just buy a second hand lsd and have it serviced? Theres probably more questions but i cant think of them right now, by the way it's and '93 EBII I6 wagon s-pac |
29-01-2007, 10:53 PM | #2 | ||
ED XR6
The EF/L Trannys shouldn't be that much better than the EB/D ones should they?
30-01-2007, 12:02 AM | #3 | |||
Tuned @ Pitlane Frankston
EA Box has shorter ratios, meaning higher reving box. EB2 to EL boxes, have longer ratios, to cope with the high diff ratios. EA's never had 3.45 diffs. So ford had shorter ratios in the gearbox to give the car some pick up and go. 2) The wiring is only for: Reverse lights, speedo and neutral switch. They have the same connections regardless of what model T5 they are. 3) Wagon tailshaft should fit? Maybe someone else knows for sure.. 4) I bought my second hand EBII XR6 3.45 LSD for about a 1/4 of the price it would have cost to get another diff made up. You can pick up bargains if you know where to look.
30-01-2007, 12:04 AM | #4 | ||
around the place
The 5 speeds throughout the models are all much the same, you'll break any one of them if you give it too much of a hard time. EA 5 speeds had a shorter 1st and 2nd gear which helps get off the line a lot quicker.
You can your current ECU use an EL auto or manual ECU (auto ones need to be modified accordingly) EL ecu it will make it go a bit better than the EB ecu. Your diff is currently 3.23:1, you can convert to LSD, or also go 3.45 gears with lsd, depends on what 5 speed you put in, the EA 5 speed goes well with 3.23, whereas later boxes are better with 3.45 or 3.7s
GPS Tracker for your vehicle - PM me for info |
30-01-2007, 12:14 AM | #5 | |||
31-01-2007, 03:32 PM | #6 | ||
ok thanks guys, so if I get an ea box or eb1 box and a 3.23 diff that will be a good combo?
And what model had the 3.23 diff in it? Thanks |
31-01-2007, 05:00 PM | #7 | ||
Parts bin special
I've got an EA box in my car, while my parents have an EBII wagon with factory T5 (so the later box). They don't seem all that different to me. Mine has the shorter first gear so that makes a bit of difference but the EA gearbox is great. The EA box doesn't have the reverse synchro while EBII onwards did, but it's still not too hard to get reverse.
As for the tailshaft, I doubt it would need changing. You don't need to change the tailshaft on sedans, so I don't see why you'd need to on wagons.
31-01-2007, 09:32 PM | #8 | ||
So What model did the 3.23 lsd come in? My main goal is to have a fast 1/4 mile wagon witch is still good on fuel so does the higher ratio make it rev higher? Who has a 3.23 LSD and what are your opinions on them? Mike |
01-02-2007, 01:55 AM | #9 | ||
