Old 22-12-2006, 03:00 PM   #1
DNKPWR
DNKPWR's Avatar
Default Heat Shielding
Just wanted to know how many of you... Put heat shielding or wrap on there headers 2 keep the engine bay temp down??
I have trouble putting the stock one back on when i got my headers.
So i just put an AU one on!! anyone do this??
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
DNKPWR is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 03:20 PM   #2
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
i havent even got extractors but i've seen a fair few people on here use AU heat sheilding. kinda a good way to hide them from the cops! too bad you cant do the same for insurance companys!
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 03:39 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
I managed to get the stock EA one back on with perry extractors, I have also given it a polish.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 03:54 PM   #4
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
hey andrew, just use the heat wrap tape. it should be sweet as.
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 03:57 PM   #5
DNKPWR
DNKPWR's Avatar
Naa..i just went 2 the wreckers and got an AU one!! much better than the EF ones, as the AU heat shield cover the 6cyl unlike the ef/EL's
Old 22-12-2006, 05:01 PM   #6
Bill_R
Bill_R's Avatar
Be careful with what you use and how thick it is. Old water pipes used to have a layer of insualtion wrapped around them. Well, turned out it was thicker than the critical radius and the heat loss actually went up.
Bill_R is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 05:13 PM   #7
havoc19
havoc19's Avatar
will this au heat shielding fit over pacemakers 4499's in my xr6?
havoc19 is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 05:33 PM   #8
XR_Lightning
Riding The Lightning
XR_Lightning's Avatar
I was just about to ask the same thing, anyone know if it fits on with no or little modification?
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA
XR_Lightning is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 07:10 PM   #9
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
au heat sheild can be easly bent and modifyed to suit most exctractors
Old 23-12-2006, 01:05 PM   #10
galapogos01
eec tweaker
galapogos01's Avatar
you can buy ACL heat sheilding on ebay for ~$50. one sheet (30x60cm iirc) will do a set of extractors easy. makes a big difference to underbonnet temps. i was worried once i melted my first brake booster (damn plastic EFs)
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2006, 01:41 PM   #11
DNKPWR
DNKPWR's Avatar
Got my au one for $5 bucks second hand... it fits of course!! Make sure u get the right one!
Old 29-12-2006, 09:28 AM   #12
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
There is a guy on the other forums who is making a custom heat shield and he has calculated that it is going to cost between $120 to $150 per heat shield depending on the numbers he gets to buy them........
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 02:18 PM   #13
SXCXR6
Whats the correct au heat shield to get guys for the ef?
Got my au one for $5 bucks second hand... it fits of course!! Make sure u get the right one!?
SXCXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 02:46 PM   #14
bentles
bentles's Avatar
got any pics of these au heat shields? i might get one soon
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 02:52 PM   #15
EA2BA
PM me if you want
EA2BA's Avatar
I still use my EA heat shield cause I have given it a bit of a polish and it was free
