Old 12-02-2007, 10:18 PM   #1
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
Default Anyone running 4.11's and a T5?
hi,
just wanting to know how you fuel consumption is? as from what i've worked out, mine will sit at 2450rpm@100km/h with 4.11's and a standard T5.
i want to go 4.11's as they are better suited but i'm a little worried about the cruising rpm.
thanks
pete j
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2007, 10:20 PM   #2
!Gn|T|0n
!Gn|T|0n's Avatar
Pm Oed666
Still saluting the Ford flag.
!Gn|T|0n is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2007, 10:47 PM   #3
Gunns
Gunns's Avatar
I know stokeb was running 4.11 but went to 3.9 cos it was bouncing on the limiter at the end of the 1/4 mile, when he had it N/A.
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2007, 10:58 PM   #4
EB Pete
EB Pete's Avatar
sounds interesting as i just worked all mine out and at 5200 (what mine bounces now) would be 159km/h. but when i do the work i have planned i hope it to make power to at least 6 grand so i should be able to take it to around 180km/h.
and OED666 is using a T5z which has different ratio's (don't have enough money to get one of those).
Old 13-02-2007, 08:32 AM   #5
BI6TIM
SnortPerformance.com
Plus the t5z is not the 'magic fix for all your gearbox problems' that people have labeled it.
I have to shake my head when I see people posting things like, 'you can't do 13's without a T5Z, thats what OED666 has' (obviously I've never heard someone say those exact words, but you get the picture).
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2007, 10:30 AM   #6
OED666
OED666's Avatar
you probably have more chance of a 13 with a normal T5... the gear box ratios are shorter off the line.
EB Pete, if your going a standard T5, get 3.9's. First gear will be useless.
I had an EA box with 3.9's and i didnt use first.
First gear times diff ratio
EA box with 4.11's - 14.385
EA box with 3.89's - 13.615
EB/ED box with 4.11's - 13.768
EB/ED box with 3.89's - 13.031
T5Z with 4.11's - 12.124
T5Z with 3.9's - 11.475
Even an EB/ED box with 4.11's is shorter than an EA box with 3.9's.
Your right about getting 180k's out of 4th at 6000rpm. I have tested this.
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2007, 05:52 PM   #7
MADED-6
MADED.6
MADED-6's Avatar
im getting 3.7s with my t5 as i drive my car everyday and do 300k to work and back so need atleast some fuel econ and sould give me alot better acceleration than my 3.27's.
ill let u know how i go.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2007, 07:48 PM   #8
Rollin
Rollin's Avatar
ROFLMAO!!!!!!
MADED-6: 3.7s should be very good for your car - you will love it
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2007, 10:10 PM   #9
EB Pete
EB Pete's Avatar
From what i've worked out, there should only be around 6km/h difference in 1st gear between a standard T5 with 4.11's (57km/h@6200rpm) and a T5Z with 4.11's (63km/h@6200rpm). it's really the cruising rpm that worrys me, not sure how much more fuel it would use sitting an extra 500rpm up on normal.
yeah i know what you mean. but 1 great thing about it is the difference between 2nd and 3rd. in a T5 2nd is 1.99 and 3rd is 1.29 where as in the T5Z 2nd is 1.94 and 3rd is 1.34, so there isn't that brief stint where the engine struggles until the cam starts to do it's magic (that happens in my car).
Old 13-02-2007, 10:54 PM   #10
OED666
OED666's Avatar
yea, the 2-3 gap in a std T5 is a littl ghey.
mine chews the juice when doing 110k's, as opposed to 100k's on the highway.
Rollins car did around 2250rpm at 100. Dont forget your cam might be a little more efficient with a few more revs.?.?.
Turbo Barra ED 4L
