Old 06-03-2007, 04:27 AM   #1
blackers10
blackers10's Avatar
Default attaching genuine side skirts
hey guys
i have purchased some genuine BA fairlane side skirts and need to figure out how to attach them?
from what ive been told they screw in with some tech? screws in the scuff plate area? where are these screws and or how do i get to them
thanks guys
Old 06-03-2007, 04:44 AM   #2
plext
Forum Director
plext's Avatar
A tek screw is a self drilling screw. Much like a normal screw but with a drill bit machined into the end.
They can be obtained at just about any hardware store.
I would be careful using them though, as the 'drill' part is not as finely made as a dinkum drill bit, any running off the intended target area could be nasty for paintwork. Personally, I would pre drill the holes with a good sharp steel bit.
I think that skirts are generally also held on with an adhesive as well as screws, certainly the skirts on my ute are, as I could see the remains when I managed to tear one of them off. It looked a lot like sikaflex, but I could be wrong on that.
plext is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 07:12 AM   #3
JefXR8
JefXR8's Avatar
Well they should have a few screws under the sill panel and a couple directly behind the wheels,then sikaflex if the door jamb area on the upper sill panel.
JefXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 07:46 AM   #4
Mechan1k
Mechan1k's Avatar
Also ... from what I remember seeing under mine (as I bought Mick's Factory kit for the ute) ... there are also flat clips that hold the skirt in place along the bottom sills under the vehicle.
Old 06-03-2007, 07:55 AM   #5
The Dok
The Dok's Avatar
There were no screws used in the scuff plate area when I did mine, if you (carefully) remove the rubber strip (that sits on top of the sill panel) the holes should mate up with the holes already in the skirt, from there it should just clip on. The underside is a different issue, you may need to use a few screws there but over all, mine was an easy conversion (considering there were none on the car previously).
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 11:30 AM   #6
S3SR
S3SR's Avatar
same here, only thing is be careful pulling it off i broke 1 or 2 of those holes in the skirts
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 11:59 AM   #7
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Yeah, I had some BA XR ute skirts that had some sixaflex still stuck on the inside of the skirt.
Holes should line up pretty much 100%, I'm not sure if you need to get the skirts cut and plastic welded like the ute cabin skirt from BA to AU.
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 12:50 PM   #8
blackers10
blackers10's Avatar
its a direct bolt on
was just wondering how they bolt/clip/glue on
thanks for the info guys
Old 06-03-2007, 05:03 PM   #9
Mark351
Built Ford Tough
Mark351's Avatar
Fit them front first, not like the morons at Paja (who marketed the whole Peregrine Falcon thing and aren't in business anymore, at least not under the same name) who first fitted my Rebel side skirts rear first then tried telling me my car must be a bit short when there was a gap at the front they couldn't fill properly with Sikaflex...
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 05:57 PM   #10
amiers
hey blackers, what did you pay for them. the loons havnt got back to me yet.
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2007, 01:55 AM   #11
blackers10
blackers10's Avatar
$120 for the pair supposed to be $200 but Botch beng such a good fellow said i could still have them for $200 (he miss quoted me)
Old 08-03-2007, 01:16 PM   #12
amiers
thats cheap!!!!! want a pic when you get them on. i dont mind the ba ones
