Well today at my tafe i came across a guy driving a NL fairlane and it was a really nice car. It was midnight blue, anyway i had a quick chat to this guy and it turns out that his car was a 195kw (gt spec) tickford fairlane? i have never heard or seen any of these models before, so i just did a quick search now and this is what i found. oh by the way anyone own one of these models??
http://blog.funtrivia.com/blogs/arch...irlane-41.html What im interested in, is that the specs on the website state that the V8 engine is multi-point fuel injected? is this true? Im pretty sure the stock 165kw EFI windsor's arnt multi-point, or are they?? regards |
Nitrous Junkie
I cant speak for the us windsor but from day one any aussie efi windsor has been multi-point.
'97 Toyota Supra - 6spd, Tilton Triple Plate, Built 2J, T88H-38GK, HKS 272 Cams, Haltech E11V2 |
windsor user
yup....always sequential electronic fuel injected - SEFI (fires the exact injector as its needed)
You win again, gravity!!!
That would be an FBT (Fairlane By Tickford) It should of had an EF Fairmont style grille with a chrome mesh insert, two tone cappa leather, and 6 spoke CSA styled mags... I want one....
![]() All e series V8s are called Multipoint Injected, but that is not entirely true. Between idle and around 1500rpm, the injectors fire sequentially, following the engines fireing order. But above 1500rpm, the injectors start batch firing, which pretty much means they all fire at the same time continually. Getting up in the rev range near red line, all of the injectors stay open all the time.
1966 Fairlane 500 XL
ahh thanks for your responses. Just checked the car manual, it does show the V8 as SEFI. Although alot of reference's i have seen just states the engine as EFI, with no S in front though.
Parts bin special
I'd love an FBT. They are easily the most desirable of the e-series based LWBs
#7 | |||
Never late with a V8
Not quite Dezza... Think Black... Think LTD... Think HO... Now tell me theres a LWB E Series ya wouldnt want more
My Rides (Daily)2004 Explorer V8 Limited (Project/Cruiser)XE Fairmont Ghia- 351 Cleveland, Toploader (Work) 2014 Kenworth K200 Aerodyne (Classic) 1969 Mini K, 1340, twin SU's The beginning is near!!! Body by Ford. Soul by NudgE
#8 | |||
Parts bin special
Riding The Lightning
I just saw one of these cars in Dandenong about 1/2 an hour ago, plates were tick24
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA |
I spotted a Navy FBT in Craigieburn today on the way to work... possibly the same one the SVT8 had seen...
I want one!
#11 | |||
The one and only
Dezza should have known better!! I'd love to own a FBT
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#12 | |||
![]() Join Date: Jan 2005
#13 | |||
VN-VR V6 engines are grouped fire through out the rev range. |
#14 | ||
![]() Join Date: Dec 2004
So what about the MPFI/BBM sixes? Do they fire individually through the rev range?
#15 | |||
At 5000rpm, combustion (and thus the intake stroke and an injector firing) will take place 2500 times in that one minute across all 8 cylinders. Thats the injectors firing 41.666 times per second, divide that by the number of injectors and you will find that at 5000rpm, one injector will have to open and close 5.208 times per second. Keep in mind that it has to stay open long enough to deliver the required amount of fuel, This is called the pulse width. The pulse width simply cannot keep up, so they either fire all injectors at the same time(Batch firing), or in the case of 5000rpm, the injector will stay open constantly. At idle and lower engine speeds the computer is able to open and close the injectors fast enough to run sequentially. For example at idle (800rpm in my case) each injector only has to fire 0.416 times per second. So obviously its much easier to keep track of. If you listen carefully, you can the change in the exhaust note when it changes from sequential to batch. My dad runs his own EFi computers and software on racecars and a few street cars... these are the basic things that must be set up when tuning these things, so you need to know how the computer is able to control the injectors. ![]() I hope that clears up sequential & batch injection a little bit...
#16 | ||
There's something wrong with your maths there.
At 800 RPM the engine is turning over 13.33 times per seconds, that's 6.66 intake strokes per cylinder, certainly not .416. |
#17 | |||
800/2 =400 400/60 =6.66 6.66/8 =8.33 ![]()
#18 | ||
You're still dividing idle firing by 8?
#19 | ||
lol, its been a long day, im applying batch formula to seqential...
IIRC it should be 800/2 =400 combustion cycles per minute 400/8 =50 combustion cycles per cylinder per minute 50/60 =8.33 combustion cycles per cylinder per second All the numbers add up to 8.33, no matter how its worked. Im dividing idle firing by 8 as I am only focusing on 1 injector, rather than all 8.
#20 | |||
Two > One
Erm, no. 800rpm is not 800 firing strokes per minute.....800rpm in a 4stroke 4cyl is 1600combustion reactions, where as in a 8cyl 3200combustion reactions. 800rpm = 400 intake strokes per cylinder (V8) = 400/60 = 6.7 intake strokes per second. Why are you dividing by 8? It doesnt matter if its a 1cyl or 200cyl engine.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
#21 | |||
"800/2 =400 combustion cycles per minute" Nowhere did I say that there were 800 firing strokes per minute. And I am dividing by 8, as I am talking about the injector pulse width of one (1) injector out of the eight in total, not the total amount of combustion strokes per second. Believe it or not, I do under stand the concepts behind the humble four stroke engine cycle, this discussion was to explain why the ECU can fire the injectors sequentially at low speeds and not at high RPM, not about the number of combustion strokes per second at any given rotational velocity.
#22 | |||
Two > One
50 combustion reactions per cylinder per minute is only an engine speed of 100rpm........ Back on Topic. You're on the money regarding the switching of sequential to batch fire as RPM increases.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - Last edited by Walkinshaw; 09-03-2007 at 10:27 PM. |
#23 | |||
Oops, I slipped....
Do E-Series V8's even use individually timed injector pulses at all? I know AU I6's do, but as far as I was aware, E-Series V8's simply had the capability to be SEFI, but the injectors act as banked the whole time.
The biggest advantage of SEFI that I can see is the self test mode, where the ECU drops one cyl at a time, and notes if there is no drop in RPM when a certain cylinder was cut from fuel. On a heavily cammed car it would help idle if it was tuned properly. Quote:
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
