Old 10-03-2007, 06:02 PM   #1
howesy
howesy's Avatar
Default Adj roller rockers
Anyone with 5.0L engine as in EL to AU fitted the adjustable version of the roller rocker (YT2028) on to the engine?
Was wondering if the adjustables still clear the rocker cover or if you need to get new covers. No one as yet can give me a definate answer so thought one of you guys might have actually done it already.
cheers.
howesy
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2007, 07:38 PM   #2
FRDTUF
FORD TOUGH
FRDTUF's Avatar
cheers.
howesy
Yeah, i was worried about that too mate... but they fitted ok to mine :
FRDTUF is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2007, 08:06 PM   #3
howesy
howesy's Avatar
what lift are you running, with the adj. under the covers and are they the 1.61 or the 1.72 's
Old 10-03-2007, 08:38 PM   #4
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
I have them on mine, i use 2 rubber/steel shim gaskets together, 1 was fine i checked it with playdoh but 2 helps me sleep at night.
Im running 1.72's in mine. With the biggest crow cam.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2007, 09:16 PM   #5
howesy
howesy's Avatar
Cheers thanx heaps.
Old 11-03-2007, 12:12 AM   #6
FRDTUF
FORD TOUGH
FRDTUF's Avatar
running 1.72's made a big difference.... :Up_to_som
Old 11-03-2007, 12:16 AM   #7
NeishaXR8_347
SS Grunt
The best way to check it is put the cover on with no gasket and turn it by hand, if it doesnt bind up take it off and put the gasket and you will be fine, the 220 used the same rollers although not adj and was fine. I like the playdoh trick as you can cut it in half and measure what you have.
