Old 04-12-2006, 10:58 PM   #1
infusion
Default New EF.. Some advice
hey guys!
i just recently purchased a ford falcon EF manual
111,000kms
just wonderin what are the biggest rims you can fit legally without any trouble with insurance.. (17's?)
and what are the standard speaker sizes for the front doors and rear parcel shelf?
cheers!
infusion is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2006, 11:14 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
both front and rear speakers are 6".. depending on brand you can get 6.5" speakers in though.
wheels depends on ur insurance, i'd ring them and find out.
17's should be an issue, 18's depends on them.
some don't care, some do.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 04-12-2006, 11:29 PM   #3
infusion
Do u know which brand/model 6.5" speakers have been known to fit?
Whats allowed by rta? i heard that u can have any size as long as you dont increase the rolling diamter by a certain amount?
Old 05-12-2006, 07:34 AM   #4
LTDHO
The one and only
LTDHO's Avatar
All speakers will fit. Off memory EF have Pioneer speakers. Quality components (or splits) in the front and some 3 ways in the rear.
What state are you in??
You will have to check with your insurer and your traffic authority.
In Vic you can go as big as you like as long as you keep withing 10% rolling diameter. Insurance will have their terms too, so call them and ask.
Tuned by CVE Performance
Old 05-12-2006, 11:10 AM   #5
EFFalcon
Last warning
EFFalcon's Avatar
Nope, but consider the depth of the speaker, deep speakers hit the window and thus won't fit properly.
Old 05-12-2006, 05:25 PM   #6
infusion
ok kool.... sorry to be annoying but does anyone know what the maximum depth is??
and im in nsw..
Old 06-12-2006, 11:05 PM   #7
infusion
hey got another problem... washed car all down... engine etc.. and now cruise control doesnt work...
the cruise light will come on but when i set acell it doesnt work... any ideas?
Old 11-03-2007, 11:27 PM   #8
fordsel/ef
Kick a Holden a day...
fordsel/ef's Avatar
ha ha sorry done this with my EL did you use high preasure hose on it if so look at the throtle body you will see two cables there one 4 cruise, check the clip on it im sure it is broken...
fordsel/ef is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 11:32 AM   #9
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
The Wheel and Tyre Guru fo Ford Froums is turbo_nick, clikd this link for some interesting reading about Wheels and Tyres of Fords:- http://www.fordforums.com.au/showthread.php?t=4160
Also he has made an Excel File to help you with
Overall diameter and circumference calculator
Metric to imperial size converter
Rim back face to outer edge distance calculator
Offset calculator and,
Backspace calculator
Click this link:- http://www.fordforums.com.au/showthread.php?t=72054
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 12:51 PM   #10
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Rule of thumb, width no wider than 1" wider than the biggest width available from factory.
You can have 21's, provided your tyres are the correct type and the width is only 1" wider than the biggest wheel available for that model.
Christiaan is offline   Reply With Quote Multi-Quote with this Post
