Old 11-03-2007, 09:10 AM   #1
slayer351
slayer351's Avatar
Default Started my new boot install.
I have finally got around to starting work on the new boot install in the EB. I have got the subs in and running and still have to do the tidy up work and a good clean.
Oh and i have to turn the responce tag around on one of the amps still too.
slayer351 is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2007, 09:18 AM   #2
jason_85
That will go pretty hard, i Have some response gear and think it is very underated!
How does your box go for volume size? i Would think with 3 12'd it would be bigger? Did you make the box yourself?
jason_85 is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2007, 09:26 AM   #3
slayer351
slayer351's Avatar
Volume is a little under size i think, I made the box to fit in the back neatly without going overboard, cause i still need a bit of boot space to carry stuff. The box was originally only housing 2 x 12" woofers but with a bit of modding it now houses the three.
It sounds very nice, Tight and punchy, the way i like it.
They are running of the responce 1500wrms sub amp, However with the wiring config i could only do with 3 dual 4ohm coils, it is only running at 2.6ohms instead of 1 ohm where the amp makes its best power.
Old 12-03-2007, 10:00 PM   #4
ROOSTA
DFDFDF
ROOSTA's Avatar
Nice.. Looking good..
Got to love the response gear.. i just picked up another 1500wrms dclass last friday..
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2007, 07:59 AM   #5
slayer351
slayer351's Avatar
Cheers,
Nik
Nik, does that give you 3 x 1500wrms amps now? Holy crap that will pump. I used to have 2 of them in my old laser hatch with 2 x 15" 1500wrms subs and managed a 150db with them. This set up isnt aimed at the high spl and more for better sound quality.
I think that the 12's give a better sound then the 15's, More punch then rumble.
I am in the middle of fitting the 7" screen into the front of the consol at the moment, will post pics up when im done.
Old 14-03-2007, 09:12 PM   #6
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
yeah that sub box seams a little undersized. i have a single 12 and the box is about half the size of that. (obvisoly a different shape)
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread
2008 FG XR8 SEDAN 300RWKW N/A
2008 FG XR6 TURBO-UTE>>> SOLD
2002 AU3 XLS UTE>>>SOLD
Sick EB is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 09:16 PM   #7
slayer351
slayer351's Avatar
Got the system all finished now, Will get pics tomorrow afternoon and post up. After all my tuning i managed to get 143.0db out of it. I am however getting a bit of cancelation cause that reading is with the boot open and with it closed i only get 138db.
I will have to build a new parcel shelf and there is the hole where the 8" sub would normally go still there which i think is causing some of it.
Old 14-03-2007, 09:17 PM   #8
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
how did u measure your db's
Old 14-03-2007, 09:37 PM   #9
JUZXR8
Hmmmmm
JUZXR8's Avatar
with a db meter
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 09:38 PM   #10
ROOSTA
DFDFDF
ROOSTA's Avatar
Wat kind of db meter???
Cheers,
Nik
Old 17-03-2007, 05:12 PM   #11
slayer351
slayer351's Avatar
Here are a few more pics of the system finished for now. I still want to do a custom parcel shelf yet, But that will be down the track a bit.
We only have one of the dbm-2 meters that you can get from caraudioaustralia.com web site. Cheap but it does the job.
Old 17-03-2007, 05:14 PM   #12
agony
BLOWN 383 CHEV OWNER
Looks like you did a good job on that install.
agony is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2007, 08:00 PM   #13
ROOSTA
DFDFDF
ROOSTA's Avatar
Gees you must work for jaycar like i do.. LOL..
Now i understand why your db reading was so high.. minus a minimum of 6 db (i have seen them read upto 20db higher) from that reading to give u a close approximation of wat u would get with a termpro db meter.. this is wat they use at competetions, etc..
Install Looks great..
Cheers,
Nik
Old 18-03-2007, 09:20 AM   #14
slayer351
slayer351's Avatar
Yep i sure do, And besides that the quality of the responce gear is great anyway. I would still run it even if i didnt work there. I am going to go to a sound off in cairns soonish to get a real reading from there meter. They have a new meter that has pressure pads that go on the screen that they got from the states and cost them somewhere around $6000 mark. So then i will have a better idea of how inaccurate our meter is.
Old 18-03-2007, 10:57 AM   #15
Hybrid34
|AFordEd|
is that an LCD screen i see facing upwards on your console?
1996 Ford Fairlane mock by tickford
EF Xr6 Engine
EF Xr6 ECU
3:4:5 LSD diff
JMM Extractors
2.5" Stainless Steel highflow cat
2.5" Exhaust
T5 transmission
Front Slotted rotors
Lowered on Pedders Sports Ryders
....and a cherry scented airfreshner
Speed determines how fast you hit the Traffic Light....Power determines how far you take it with you.
Hybrid34 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 11:05 AM   #16
slayer351
slayer351's Avatar
Yep its a 7" responce screen i mounted in the front pocket of the consol.
Old 18-03-2007, 02:33 PM   #17
XR6_661
Cane Farmer
XR6_661's Avatar
Is that the sound off at Autobarn?
Let me know when you are going and I'll come and have a decent look.
XR6_661 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 04:51 PM   #18
slayer351
slayer351's Avatar
Yep thats the one, I will keep you posted when i get a chance to come down for a run.
Old 18-03-2007, 05:34 PM   #19
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Let me start by saying that im not a huge fan of big systems (i used to be but lost interest) but the standard of finish that i have seen on members systems in this club is excellent. Slayer351, well done it looks great.
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
