Old 04-04-2007, 02:16 PM   #1
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
Default Quick Question
i have an auto eb. i was in my street and wanted to see how my car went. anyway i put the 'power' switch on stalled it up a bit then let it go. to my surprise it got up to 80k's in first before it decided to change (flat out). then after it changed i slowed down straight away, not to be too dangerious.
i dont want a discussion that i should not have been doing it or what i just want to know if that is normal or is it holding the gear too much. i dont have a rev guage so i dont know what it was hitting.
matt.
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread
2008 FG XR8 SEDAN 300RWKW N/A
2008 FG XR6 TURBO-UTE>>> SOLD
2002 AU3 XLS UTE>>>SOLD
Sick EB is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 02:19 PM   #2
Allen
You win again, gravity!!!
Allen's Avatar
The BTR trans do have a very tall first gear, but it will also depend on what diff gear ratio your car has...
Reading through my manual, the 1-2 gear change at 100% throttle happens at 66km/h. This is with the trans in "D" shifting at roughly 4000rpm
This is on a 5.0 with a 3.23 diff ratio.
If you have a standard 3.08 diff ratio, 70-80 km/h sounds about right for redline being held in first gear.
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 02:20 PM   #3
eMpTy
Low, Loud & Black
eMpTy's Avatar
With power on our EB usually shifts 1st > 2nd at 80-90km/h, have to lift off slightly for it to shift though.
Held down in 1st it has wound out to 110km/h on the highway, wouldn't want to do it too often though.
eMpTy is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 02:25 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
110km/h in 1st gear in an EB?
somethings not showing a true reading.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 04-04-2007, 02:26 PM   #5
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
I'm lucky to get to 40km/hr in my car.. EA T5 + 3.45:1 = short.
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 02:26 PM   #6
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
sorry the car is a 4L I6 with stock diff (not sure what it is) single spinner. and that the first time i have taken it that quick and i dont plan to much more.
Old 04-04-2007, 02:26 PM   #7
Christiaan
Christiaan's Avatar
hahahahaha, 110?
That's not right mate.. have you changed diffs or speedo gears lately?
Old 04-04-2007, 04:09 PM   #8
mcflux
mcflux's Avatar
I hit 110 in 1st once in my car when I had 3.27s. Mind you she bounced off the limiter at the time.
Old 04-04-2007, 04:53 PM   #9
El Venom
normality is boring
El Venom's Avatar
hey i got a stock 88 ea fairmont ghia wagon with 3.9 mpfi and 3 speed auto to hit 110km/h many times
El Venom is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 04:57 PM   #10
OED666
OED666's Avatar
max i could get out of mine when it was auto with 3.08 diff was 84k's. that was ringing its neck.
i think i get around 45-50 out of first with 2.95 first and 4.11's (Manual).
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 05:39 PM   #11
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
so by what everone is saying my car doing that is pritty much normal, even a bit slow. lol
Old 04-04-2007, 06:18 PM   #12
mcflux
mcflux's Avatar
But that's with a similar 1st gear ratio to a BTR and a 2.77 diff. Much more easily acheivable
Old 04-04-2007, 06:53 PM   #13
adumb
FG G6ET
adumb's Avatar
My Ghia frequently changes 1st to 2nd at 80ks with econ on and off, thats whith a 4 speed and 3.45s
adumb is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 07:06 PM   #14
webby_191189
low wagooon
Mine changes around 80 from 1st to 2nd in a stock Ef I6 4speed auto. Revvin around 5200-5300 i think
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 10:48 PM   #15
ROOSTA
DFDFDF
ROOSTA's Avatar
{I could get my old auto to stay in first till i hit 140kmhr.. cos i moved the speedo needle..** Sarcasm...
Does it really matter wat speed the gearbox changes at??? I would usually be looking more closely at the tacho to get a indication of whether its normal or not as the speedo's in e-series can be quite a bit out.. i haven't seen a tacho that was out aside from one that a guy put the needle back in so it pointed to 2000rpm at idle.. bloody idiot..
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2007, 11:12 PM   #16
eMpTy
Low, Loud & Black
eMpTy's Avatar
Only change made was going from 14" to 15" wheels, rest is original.
Was a pretty steep grade I was traveling down at the time. Have only hit 110 once and wouldn't want to try again, sounded ready to blow up.
