21-04-2007, 08:37 AM | #1 | ||
Only an xr6...
Hi all, It's time I need to service my engine and instead of paying $500 to get the 1st year apprentice at ford to do it I thought I'd like to learn more about what's what in my new car. So I've decided to do all the fluids and everything I can do by myself. So here come the questions.
What can and should I change in my car, It's done 75000 K's and so far I'm thinking I'll change oil/air filter, Oil, brake fluid, clutch fluid, diff fluid and I think thats all I know. I have a freind who's agreed to do all the technical stuff like timing ect. So is there anything else I can check or change by myself and what brand would you buys recomend for the fluids and all that. Is it worth getting a K&N filter? Sorry for that overload of Questions but I'm still trying to learn about cars. |
21-04-2007, 08:46 AM | #2 | ||
Aftermarket airfilters are great ive had all 3 brands K&n-redline-kingdragon and they do all the same thing just huge differance in pricing as for the timing wont be needed if the car is running smooth.
And as for servicing at ford been there done that tools kept breaking bits on car : and dont always go for the expensive brand of oils as i reckon they all do the same thing lastly check youre spark plugs and ignition leads but i dont think with the minumal amount of kays you have that you need to change all the fluids though. i aint a mechanic but i do most of my repairs myself as workshops are like the goverment love ripping you off.
18 T6 Multivan 03 Ba Xr turbo 300rwkw |
21-04-2007, 09:27 AM | #3 | ||
replace
Oil Oil filter paper air filter, put your vacuum cleaner in your air box and clean out any bugs etc spark plugs plug leads (if necessary) reseting your ECU when servicing can also help engine smoothness and performance also a good idea to check and replace your coolant if needed save $$$ doing it yourself ,plus its not that hard and quite enjoyable working on your own car i think. cheers gary
21-04-2007, 09:28 AM | #4 | ||
Only an xr6...
My diff has been getting a fair bit of work latley which is why I want to change that. So do you think I should put off the clutch and brake fluid till 100 000 K's. How do I reset my ECU?
21-04-2007, 09:31 AM | #5 | |||
21-04-2007, 09:35 AM | #6 | |||
Only an xr6...
21-04-2007, 11:11 AM | #7 | |||
21-04-2007, 01:18 PM | #8 | ||
Only an xr6...
Ok I've changed the oil oil filter put in the K&N air filter and some bosch spark plugs. I just wish I shopped around for good spark plugs as I wasn't thinking when I bought them. Now could anyone tell me how to reset the E.C.U?
21-04-2007, 01:21 PM | #9 | ||
have a check of your cooling system hoses, any signs of leakage , and check battery and terminals as well.
21-04-2007, 01:56 PM | #10 | ||
I bung a bottle of injector cleaner in the fuel tank every service and change the fuel filter every two years.
regards Blue |
21-04-2007, 02:58 PM | #11 | |||
Blown 5L coming
bets thing to do if you want to do your own service, and this is what us mechanics tend to do, is get the owners manual out of the glove box, turn to the service schedual book and look up the service that is recommended for the amount of kms you have done. it has a little check list on it that ford recommend needs doing at each interval. then look for other things while doing that service that may require attention, check all over for leaks (brake cylinders, axel seals, cv boots, diff seal, trans seals, rocker cover, power steer pump, head gasket, etcetc, and not just oil but coolant as well) check that your brake pads still have a bit of meat on them and that tyhe rotors are wearing evenly (no grooves, and check for lip depth - rotors may need machining) as well. hope this helps
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
