Old 21-04-2007, 03:41 PM   #1
Tony_4500
Default No reverse "where did it go?"
Hi all, I started my car today and when I put it into reverse it just reved and didnt move, it finally moved slowly but as soon as I touched the accelerator it just reved like it was in Neutral. All other gears are fine and working. When I put it into reverse it dosent give the little clunk to let me know it's in gear. I only had the gearbox serviced in December and I dont drive it hard.
Cheers Tony
Tony_4500 is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2007, 05:06 PM   #2
JC
Miami Pilot
JC's Avatar
It could be the inhibitor switch - get under the car, disconnect all the electrical connectors plugged into the gearbox, and spray liberally with WD40/RP7/"Start Ya Bastard". Reconnect and it should be good.
If it';s not that, then it could be that the Transmission fluid will be low - top it up quick.
Ford Performance Club ACT
Old 29-04-2007, 09:05 AM   #3
Umineko
Karasu
Umineko's Avatar
I had this problem crop up with my old ZH LTD turns out the servo for the first gear clutch died so when she went in to reverse it was actually in first and reverse at the same time, Rev it hard and reverse gear being a lower ratio would win out and it'd creep backwards slowly (not recomended... my ex wife discovered this and cost me a new tranny because of it) don't know if the AU Trans would be subject to a similar problem
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2007, 09:22 AM   #4
JC
Miami Pilot
JC's Avatar
Um...thanks for sharing, but if you don't know if this would be the problem in an AU, why suggest it? ZH is what, 1984? AU is 1999 - 2002; a world of difference between a mechanically controlled box and one with electronic controls as well.
Old 29-04-2007, 11:03 AM   #5
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
take it easy JC , he is only sharing his veiw on the situation
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2007, 11:38 AM   #6
toyotaxr8
toyotaxr8's Avatar
if the connectors aren't dirty it will most likely be the revers solenoid is acting up
MR INCH
toyotaxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2007, 03:10 PM   #7
Umineko
Karasu
Umineko's Avatar
Hmm Ok maybe my reply was not directly related to the AU and yes autos have come a long way in the years between models IE electronic computerised control verses mechanical kickdown linkages, that said however the basic opperation inside the transmission hasn't really changed a great deal, it still works with bands, planetary gears, hydraulic valves and servo actuated clutches, thus the same problems that occured in a transmission of 10 to 15 years ago can occur today (and a whole host of new problems) the electronic systems control gear shifts and kickdown, but as reverse is still mechanicaly selected and has no kickdown system I think my input was valid. I certainly didn't mean to put any ones nose out of joint though, and apologise if I have done so
Old 29-04-2007, 03:30 PM   #8
atec77
Cheers Tony
Check and clean g/box electrical connectors , then is the fiuld right ?
if this doesn't work then either the soliniod is faulty or it's split the planetary .
atec77 is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2007, 03:33 PM   #9
JC
Miami Pilot
JC's Avatar
Yeh, sorry - lack of sleep to blame on my part!
Old 29-04-2007, 03:36 PM   #10
Umineko
Karasu
Umineko's Avatar
No probs JC, cheers mate
Old 29-04-2007, 10:21 PM   #11
GK
Walking with God
GK's Avatar
Smile
All is well in the land of AU again! LOL!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
