Old 01-05-2007, 07:40 AM   #1
low-eb
low-eb's Avatar
Default Turbo E-series what transmission
hey guys just wondering what transmissions you guys are running with your turbo motor and what kinda of work is done to to the trans and what power are u running thru it?
Link to my car thread> My eb Spak
low-eb is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 07:51 AM   #2
LTDHO
The one and only
LTDHO's Avatar
Stock.
EFFalcon has a standard one (will up until a few weeks ago) then he upgraded the shift solinoid. He's be giving that trans around 230kw's.
snypereb is running similar power through a worn T5. He just upgraded the clutch.
Tuned by CVE Performance
Old 01-05-2007, 07:52 AM   #3
Gunns
Gunns's Avatar
T5 good for around 220rwkw
BTR 4 Speed good for up to 300rwkw if rebuilt with all the goodies
TKO around the 450rwkw
T56 up around the 500rwkw
C10 750rwkw
Powerglide some stupid amount of power.
Just to throw a spanner in all these figures Eddie Testone still runs a T5 in his 1300rwhp commodore, but it is a dyno queen.
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 07:54 AM   #4
EFFalcon
Last warning
EFFalcon's Avatar
180rwkw through a standard 240,000km 4 speed BTR, AU S5 solenoid and twin factory coolers.
6 months of hard abuse and still going well
only ever had 2 services in its life :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 01-05-2007, 06:28 PM   #5
low-eb
low-eb's Avatar
any one running KEAS built C9, C10? is it worth gettin one?
Old 01-05-2007, 07:07 PM   #6
Rollin
Rollin's Avatar
I blew a T5 apart with just over 200rwkw...they are dodge.
MV Automatics reckon they can build a BTR to handle about 600rwhp, or supply just a valve body for about 400rwhp on a good condition but otherwise stock box.
If you don't have very sticky tyres you can keep a T5 alive for longer, because the tyres will absorb some of the torque (in smoke hehe)
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 07:16 PM   #7
maz1300
maz1300's Avatar
i have a rebuilt c9 sitting here still! state 2 shift kit not looking for 2 much it come off a 250 crossflow!
maz1300 is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 08:04 PM   #8
Sundeep
Sundeep's Avatar
Use the standard 4 speed with a electronic shift kit, massive trans cooler and good oil.
If it blows up buy one for $50 (there's plenty around, look hard enough) and either fit it yourself in a couple of hours or get a cab depot to do it for $150.
They're good until a solenoid goes or a band goes. Then they give you all sorts of trouble.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 09:16 PM   #9
Gunns
Gunns's Avatar
TUFED6 has a KEAS C9 with a manual valve body.
EASPRINT is getting a C10 from Big Lukes House of Horsepower with a transbraked reversed pattern manual valve body. The same as the one in the JMM red EB.
STOKEB has a C4 with a manual valve body.
Old 01-05-2007, 09:35 PM   #10
fritzz
fritzz's Avatar
i have a 40,000km stock btr auto with a electronic shift kit.
lasted a year on 220rwkw with no problems at all.
my car now has 287rwkw and the auto slip's really badly, some times it wont even change gears and sits on the limiter.
# 1997 EL Falcon GLI - Custom built AU 4L bottom end, Billet Turbos B76-GTS, Nizpro plenum, 6boost manifold, Autronic SM4, Custom billet surecam camshaft, 3x 044 pumps and custom undercar surge tank, Custom 4" exhaust, ID2000 Injectors, 60mm Turbosmart gate, Turbosmart race port bov, , Tremec TKO 600, Cebco 330mm Brakes, 3.7:1 9" diff with billet axles and trutrack center 608rwkw, 9.6sec 1/4mile
# 2008 FPV FG GTE - Xa Coilovers, 20x8.5/ 20x10 fairladys
fritzz is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 09:37 PM   #11
ROOSTA
DFDFDF
ROOSTA's Avatar
So not many people have success with the T5 over 220kw hey??? Thats not much good cos i just did a auto to manual conversion and never want to go back..
How hard is it to fit a T56 to our 4L engines???
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 09:44 PM   #12
Simmo
White Lightning
Simmo's Avatar
check out Rollin's workshop thread. its all fitted now and well documented.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2007, 05:15 PM   #13
Obriza
Obriza's Avatar
Im still running a stock box with 190rwkw... It seems to be going alright with some pretty hard driving
Obriza is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2007, 06:50 PM   #14
snypereb
[EBGLT]
snypereb's Avatar
As wayne said im running a standard t5 with a really good clutch I wanna send my spare t5 away to be upgraded to t5z spec.
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2007, 06:55 PM   #15
krisisdog
krisisdog's Avatar
Is there strength differences between EA-EL 5speed boxes? I know there are minor changes but you would think the EL would be stronger than EA, wouldnt you?
krisisdog is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2007, 06:56 PM   #16
ED turbo (mickmalta)
I've had no probs with BTR 4 speed autos.
Mick: 2000 camry Wagon (bog stock)
1984 Pontiac trans am
Gone but not forgotten: 1993 Falcon futura turbo.
ED turbo (mickmalta) is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2007, 07:07 PM   #17
JD86
DELANY
JD86's Avatar
standard t5 with xr6 clutch
2010 FG XR6T - 6 speed manual - luxury pack
JD86 is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2007, 07:19 PM   #18
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
the keas auto's are a good box from what i have seen, Paul is helping me with advice with my c10 for my turbo 302, there is soo many little things that can be done to them to help them live, and then there is aftermarket parts like input shafts and stronger planetarys for 500+hp applications.
Qwikcorty is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2007, 11:05 PM   #19
sphell
sphell's Avatar
I rang up a trans place about the BTR's last week, cause I was looking at rebuilding mine. They sell rebuild kits for $395 DIY, and also a 'race' kit which is $795 DIY. That included upgraded valve body, stronger bands and a bunch of other stuff. They reckon it'll handle 450hp with a 3.08 diff, or 500-550hp with a higher diff ratio. For them to put it all together with a new converter it was about $3k.
sphell is offline   Reply With Quote Multi-Quote with this Post
