i need to know how to set the car back to factory setting so it can learn new things
![]() Join Date: Jan 2005
Disconnect the battery for 45 minutes or so, then reconnect it.
If you did a search for "reset" you would've found this in the results: http://www.fordforums.com.au/showpos...10&postcount=5
a bit more to it than that once you reconnect it you need to do the following
1 start engine A/C on & idle 2 min 2 turn A/C off idle 2 Min 3 put in D A/C on idle 2 min 4 Turn A/C off idle 2 min drive for 5 minutes changing speeds and throtle positions as much as possible ECU is now reset but will learn further from your driving |
#4 | |||
make sure you do not have the A/C on when you first start the car. just refering to No 1 on your list. start it first let it idle for a bit then turn it on. this is probably what you ment anyway ![]() ![]() ![]()
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
yes was just a bit unclear sorry follow everything in exact sequence and you'll be spot on so I really should have said start engine then switch A/C on etc
