18-05-2007, 07:00 PM | #1 | ||
Previously TUNGA
can some one tell me if the cam in these moters is belt or chain driven
if its a belt .when should it be replaced |
18-05-2007, 07:03 PM | #2 | ||
Back to the AU
Chain driven mate. As for when it needs to be replaced, have you checked here?
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU 2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth |
20-05-2007, 08:32 PM | #3 | ||
mezzo forte
The chain should never need replacing.
20-05-2007, 10:39 PM | #4 | ||
yer you dont need to replace the timing belt, cause it doesn't have one... they are chain driven and should never need to be replaced, under normal circumstances
21-05-2007, 09:44 PM | #5 | ||
Even taxi usually doesn`t change chain belt
They use nomarly driven around 600 000km to 800 000km but I never see they replace chain belt...(I saw replace Engine) On normal condition I think you don`t need to worry about chain belt... Except If you drive Really High Revs all the times.. |
21-05-2007, 10:07 PM | #6 | ||
i drive a cab with over 800K no chain noise never been replaced original engine are these engines good or what
