08-06-2007, 11:55 PM | #1 | ||
I was just wondering how I'd use a torque wrench.
What I have been doing is turning it normally until it clicks, and after that I tighten further extremely slowly (so there's less torque from me) until it clicks again. Is this the correct way to use it? |
09-06-2007, 12:03 AM | #2 | ||
:D:D
well then u have the torwue setting you want you use it like a normal ratchet but once you hear it click then the bolt has been torqued up
Cheers Grant |
09-06-2007, 12:16 AM | #3 | ||
Depends on what type of torque wrench, but the main thing is not to try to undo bolts with it
Pit Lane Performance 20 Rosella St Frankston 03 9783 8122 Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
09-06-2007, 12:39 AM | #4 | ||
why can't you undo bolts with it?
It was a wrench from autobarn, unsure of brand. I'll just use it like a ratchet then |
09-06-2007, 12:32 PM | #5 | ||
("(O.o)") Fear the EL!!!
Try not to undo stuff with tension wrenchies, you can send it out of calibration, when you use a tension wrench, the first thing you do is set up what tension you want it to click at, say 50nm, you set it and you tighten the bolt accordingly, try to keep it a smooth movement, no big spikes as that can cause a misreading, you can go either fast or slow, preferably medium speed, if you were doing up something like head bolts you can warp the head if you tension to quickly.
There are other ways to tension, some head bolts say, 210FTLB (Example) and then 90 degrees, that means you tension the bolt to 210 FTLB then you go mark the bolt and then you rotate the bolt 90 degree's. I don't exaclty no why idiot companies like Izuzu do this, i work on trucks for a living, maybe gives them a more accurate torque, there are other wrenches to, like angular wrenches that make doing the degree's tensioning really easy Regards Macka!
04 Silver BA XR6 Turbo, Now with 241RWKW thanks to CV Performance! : |
09-06-2007, 07:25 PM | #6 | ||||
see http://www.canadiandriver.com/articles/jk/040303.htm Quote:
regards Blue |
09-06-2007, 07:28 PM | #7 | ||
Well said, i'm only a first year apprentice dont know that much as of yet :P
09-06-2007, 07:29 PM | #8 | ||
Even better again
09-06-2007, 07:36 PM | #9 | ||
I'm in my mid 50's and still learning and all I know for certain is nobody knows it all. And the beauty of this forum we all share what we know and all contributions are appreciated.
As for using a torque wrench see http://www.virginiawind.com/tips/torque_wrench.asp
regards Blue |
09-06-2007, 07:41 PM | #10 | ||
I use them everyday lol, best tool ever, i just didn't understand why they dont just make a set tension instead of saying "lets add another 180 degrees onto that" lol :P
