Old 11-06-2007, 12:11 PM   #1
cheeza5
cheeza5's Avatar
Default Driving Lights- How many watt's?
Hi all,
next few days i will be installing driving lights into my EL. i want to know how many watt globes i should get? i have seen 55 and 100 watt at supercheap.
The lights will be on at the same time as the low beams so i was thinking the 100 watt light would be to bright but i am not to sure.
those with driving lights what setup do you have?
OLD - EL Fairmont 97'Heritage Green,tickford bodykit, Tickford Gas, Pacemaker extractors, 2.5 exhaust,Blue and Red LED dash, Mirror Tint, Superlows all round, with 18' Advanti rims NOW T5 conversion
cheeza5 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 12:23 PM   #2
Kenster
Kenster's Avatar
I would recommend to talk to one of the staff possible at supercheap or autobarn or repco they would able to help you. But in fitting its just matter of wiring with the headlights relay
Kenster is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 12:28 PM   #3
cheeza5
cheeza5's Avatar
Yeah i dont have a problem with the wiring i was just not sure if i should use 55 watt globles or 100 watt globles?
Old 11-06-2007, 12:48 PM   #4
Kenster
Kenster's Avatar
hmmm i say 55watts globals im not too sure on that but best to get a referes
Old 11-06-2007, 01:03 PM   #5
EFendedXG
You mean the fog lights in the bumper mate i would be staying 55w or eaven 65w if you can get you hands on them....
Old 11-06-2007, 01:07 PM   #6
cheeza5
cheeza5's Avatar
Yeah i am after fog/driving/cornering lights, so many names these days!!
i was thing 55 might be the way to go. 100w is just to bright.
Old 11-06-2007, 01:14 PM   #7
holmsy
holmsy's Avatar
i dont suggest talking to the staff at supercheap.
repco is better.
supercheap half the staff are to young to even have a license let alone know anything about cars.
repco actually has mechanics.
holmsy is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 01:16 PM   #8
LUXO_8
windsor user
you know that running driving lights off low beams is illegal.......
dont run 100w globes in driving lights on low beam anyway, thats worse than having your high beams on at someone......
Old 11-06-2007, 01:17 PM   #9
EF302
i put some 55w driving lights on mine the other day and they are definately bright enough, 100w would be too bright
EF302 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 01:23 PM   #10
cheeza5
cheeza5's Avatar
by that you mean having them on at the same time? if so BA/BF XR have both on, along with other cars, eg WRX and commodores
repco is better.
that is very true, the supercheap is Warragul is run by a girl i went to school with, and she knows nothing about cars!
Old 11-06-2007, 01:28 PM   #11
LUXO_8
windsor user
you'll find that they're fog lights, and if you have them on in conditions that dont warrant them, you'll cop a fine
Old 11-06-2007, 01:33 PM   #12
cheeza5
cheeza5's Avatar
Yeah i understand that, i am going to put a switch in so they can be turned on and off when ever i need to.
Old 11-06-2007, 05:16 PM   #13
gthofan
Gunna girlie-man
gthofan's Avatar
i have 130w globes in my high beams mmmmm sunny.
But i agree with everyone else, just keep 55 for head lights and fog lights.
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 11:02 PM   #14
SDKC
To punish and enslave
SDKC's Avatar
Driving with fog lights on at any time of the day in any conditions is not illegal.
SDKC is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 11:09 PM   #15
BenJ
BenJ's Avatar
In NSW it is.
You can only use them if the conditions are poor.
BenJ
BenJ's EB Ghia Wagon - Current Ride - AFF Projects
BenJ's EB Ghia Wagon - OzECruisers
BenJ's Budget Buildup - Old Ride
My respect and thanks go to - snap0964, Paulmac, SWC and MRE-50L
BenJ is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 02:04 PM   #16
SDKC
SDKC's Avatar
Originally Posted by BenJ
In NSW it is.
BenJ
I went to the RTA (NSW) website and discovered NSW Road Rules funnily enough are the same as the Victorian Road Rules, funnily enough because the Road Rules are Australia wide.
Road Rule 217 Using rear fog lights
(1) The driver of a vehicle fitted with a rear fog light must not
operate the fog light unless the driver is driving in fog or other
hazardous weather conditions causing reduced visibility.
Offence provision.
(2) In this rule:
rear fog light means a light fitted to a vehicle to make it more
easily visible from the rear in fog.
Road Rule 219 Lights not to be used to dazzle other road users
A driver must not use, or allow to be used, any light fitted to or
in the driver’s vehicle to dazzle, or in a way that is likely to
dazzle, another road user.
So I did a search on keyword "fog lights" and got this:
Originally Posted by NSW RTA website
Daytime running lights
By simply using daytime running lights (DRL's), the visibility of your car is increased substantially to both pedestrians and other drivers.
It is necessary however that the correct lights be used. Fog lights and high beam are inappropriate and parking lights ineffective whilst driving. Until specially designed DRLs are installed, low beam headlights are the most effective way to make your vehicle more visible.
A recent NRMA report has found that DRLs could prevent a quarter of all fatal daylight collisions and more than a quarter of fatal daytime pedestrian accidents.
A combination of a light coloured vehicle and turning your low beam headlights on during the day will make it easier for other road users to not only see you but also to better judge the distance between themselves and your vehicle. This equates to less risky manoeuvres being undertaken.
Nowhere in this article does it tell me that it is illegal to use fog lights during the day, just inappropriate, and before you say but it also says that high beam lights are inappropriate, there is a specific offence in the Australian Road Rules governing the use of high beam lights.
But that is all the research I'm going to do in NSW. I'm a Victorian copper, I don't care what happens in other states.
