Closed Thread
Old 10-06-2007, 09:27 PM   #91
galapogos01
eec tweaker
galapogos01's Avatar
Originally Posted by MADNC_8
AFAIK the only thing that happened with the k frame was the front crosss bar cut out for clearance........would have taken nothing at all to weld in a new bar at the front of it and hit it with some paint....
how many mechanics would roady a dodgy kframe weld, eh?
galapogos01 is offline
Old 10-06-2007, 09:37 PM   #92
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
I know plenty As long as vicroads don't need to see the car, you're laughing!
Christiaan is offline
Old 10-06-2007, 09:39 PM   #93
galapogos01
eec tweaker
It had to go to vicroads, it was unregistered.
Old 11-06-2007, 08:57 PM   #94
Christiaan
Christiaan's Avatar
Yeah but a roadworthy accompanies the car.. I doubt a vic roads inspector is going to notice a well welded k-frame cross member..
Old 11-06-2007, 09:02 PM   #95
[T1PTOP]
why would you cut and shut when the other alternative works fine?
[T1PTOP] is offline
Old 11-06-2007, 09:13 PM   #96
LUXO_8
windsor user
waaaay back when it was done, it wasnt really well known how to do it..... so the k frame front crossbrace was cut out, with a new piece to be welded in infront of it, to give around 10/15mm more clearance...
it would have been perfectly fine, as its not really all that much of a structural brace...(its only 10x10 tube isnt it?) and welding it across the front of the k frame would be just as strong as it welded in its standard location...
it would have worked just fine.
looking back though, if it was known you could shave the front of the sump to achieve the required clearance, it more than likely would have been done that way
LUXO_8 is offline
Old 11-06-2007, 09:21 PM   #97
bobsmythe
Is this what you found when you did the conversion?
Got any pics?
bobsmythe is offline
Old 11-06-2007, 09:23 PM   #98
[T1PTOP]
not saying it wouldent work im sure it would work fine as long as the wields are done proper.
but when it comes to RWC and Vic road related side of it, id imagin it be a bit of a pain to get it cleared as you would need an enginers saying the k-frame is fine and is structualy sound.
grinding the sump is somthing no one would notice and would pass a RWC np's (even at the most stringent RWC place)
im just saying one way of doing it is alot easyer then the other
[T1PTOP] is offline
Old 11-06-2007, 09:29 PM   #99
LUXO_8
windsor user
Got any pics?
never did it myself but was there when it was done on jacks car.........
eh, at worst you could toss in another k frame........4 bolts and jobs done,
LUXO_8 is offline
Old 12-06-2007, 11:44 AM   #100
Sundeep
Sundeep's Avatar
Yep, the 4 bolts and the rest of it... likeeeee suspension, engine mounts, stabiliser bar etc. etc.
Sundeep
Sundeep is offline
Old 12-06-2007, 05:57 PM   #101
ilsautomotive
Former E-Series Member
Well guys, regardless of whatever might have been, I think it might be time to put this thread to rest. ;)
ilsautomotive is offline
Closed Thread
