Old 15-06-2007, 03:03 PM   #1
ILLaViTaR
ILLaViTaR's Avatar
Default Update on car, not starting now
Ok I just refilled the cooling system correctly.
Now after all that the car aint starting.
These were the problems in order.
1. Car ran rough, low idle.
2. Car ran rough, low idle and when I cranked the ignition it sounded weak.
3. Car not starting making a ticking noise.
Member Aussiblue suggested when I changed the themostat water got into the TFI module. But since it's not starting at all could the TFI be dead?
I'm going to buy the thermal paste now
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2007, 03:06 PM   #2
james22
With da Warlords
james22's Avatar
ticking noise, generally means flat battery, and it would also explain your weak cranking. Test your battery, or plug a jumpsarter to it and see how you go
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2007, 03:08 PM   #3
xrtonv
TICKFORD XR6
xrtonv's Avatar
yer flat batery or the starter is stuffed some how. had the same problem in my old XD the startedmotor had broken some teeth and thus make a ticking noice.. not sure if this help but
dimi
The Ride:Ford EF XR6 S1
The Drive Line: 4.0L MPI 4speed Auto TICKFORD ENHANCED
How she Rides: 15inch XR6 MAGS
Sound system:JVC head unit with AUX... 6 Inch in doors,rear with a Vnet 15inch & Infinity 12inch Subs In the Boot Running of a Coustic amp
The Mods: Pod Filter, exhaust......
Plans: Slam it on its ***, Sports exhaust( upgrade), Rims, Cam, CAI, Extractors +...
xrtonv is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2007, 03:12 PM   #4
ILLaViTaR
ILLaViTaR's Avatar
Yeah straight after I posted I thought of the battery and yeah it's dead.
I'm charging it now.
I left the boot open overnight accidently, the weak cranking was before I done that though.
Old 15-06-2007, 03:18 PM   #5
xrtonv
TICKFORD XR6
xrtonv's Avatar
it could be the battery gone and some plates not giving any charge for the weak crank???
Old 15-06-2007, 07:20 PM   #6
ILLaViTaR
ILLaViTaR's Avatar
Ok charged battery and it cranks better but it still idles low.
I've cleaned out the TFI module with WD40 and applied some thermal paste.
It's idling low and the exhaust is white and stinks of petrol I think (engine is cold to afraid to leave it on for more than a minute).
I know white smoke could mean head gasket but would that also explain the low idle and it alomst stalling?
Old 15-06-2007, 08:29 PM   #7
jjj
jjj's Avatar
Take the coolant reservoir cap off and check for air bubbles in it or steam coming from the overflow resvoir hose while the engine is running. That is a sign of a failured head gasket or cracked head. More likely the 2nd.
jjj is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2007, 10:06 PM   #8
ILLaViTaR
ILLaViTaR's Avatar
How long do I have to run it for???
It's running horrible and I don't want to damage it.
I ran it for 4 minutes and no steam at all.
Symptoms are it's idling low and sometimes goes extremely low and stutters a lot.
Also there's a smell from the engine bay and mainly the exhaust, it smells heavy of something but not petrol.
Old 15-06-2007, 10:20 PM   #9
jjj
jjj's Avatar
was there any air bubbles in the coolant when you looked inside the reservoir tank while the engine was running?
The smell might be burning coolant, take the exhaust heat shield of the exhaust headers( about 4 bolts) and have a look below the head for white stains running down the block. That's a sign of leaking coolant from the head gasket and is a common place that they start to leak from first.
Old 15-06-2007, 11:19 PM   #10
ILLaViTaR
ILLaViTaR's Avatar
Nope see nothing there thank god.
IMPORTANT UPDATE.
I just done a cylinder compression test and the numbers look fine.
Last time I ran it (3 weeks ago before I touched anything) I got 198-203psi.
But engine was at normal operating temperature.
I only ran in for 4 minutes this time because I was worried about damaging it.
This time round I got 196-198psi but I'm guessing that's because the oil wasn't hot right?
Also a cracked head or head gasket would see PSI ratings way below that yeah???
Old 16-06-2007, 12:22 AM   #11
yahoo189
yahoo189's Avatar
Coil Pack? I got a new one and it fixed me. I had the same problem. I bust a radiator hose, car overheated, then would'nt start, when I tried it made a ticking noise, like crazy smartlock spasm, then a few days later I needed to get a new battery. Also found out the the valve on the 5th cylinder had warped. bugger.
Hamish
ED, Lowered Lovell Springs, Monroe GT gas shocks, SAAS Racing Buckets, SS Lab Sound System, Carbon Fibre Wheel, Full Sports Exhaust System.
yahoo189 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2007, 06:13 AM   #12
70caprigt3k
Nitrous Junkie
70caprigt3k's Avatar
Have you disconnected the battery at any stage recently?
'97 Toyota Supra - 6spd, Tilton Triple Plate, Built 2J, T88H-38GK, HKS 272 Cams, Haltech E11V2
70caprigt3k is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2007, 10:12 AM   #13
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
IMPORTANT UPDATE.
Umm, you don't run the car while doing a compression test? You remove the leads, remove a spark plug at a time, put the compression tester in the hole, and crank the car over for a second to get a reading on the gauge.. ?
Or am i completely wrong?
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2007, 10:23 AM   #14
Psycho Chicken
Psycho Chicken's Avatar
Yeah don't run it while you're doing a comp test. Unplug the coil when you do it and make sure you crank it for the same time on each cylinder.
Did you end up cleaning the ISC?
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2007, 10:59 AM   #15
snypereb
[EBGLT]
snypereb's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
This should probably be in the tech area!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2007, 07:42 PM   #16
ILLaViTaR
ILLaViTaR's Avatar
Hmmm.
Engine sounds fine now, exhaust sounds a bit bassy but unsure if it was always like that.
I havn't cleaned the ISC yet, I heard you need a special cleaning fluid?
How often should I clean it?
It was last cleaned 20 000k's ago
Old 16-06-2007, 08:13 PM   #17
jjj
jjj's Avatar
Hmmm.
Maybe you just got a tank of really shitty fuel? it does happen now and then and can make your engine run rough as guts. Maybe a new fuel filter for $20 might be on the cards.
It has happened to my car before, fueled up at a no name servo and within 100km the car idled like ****, had no power. But after the tank got down to 1/4 i fillled it up with vortex and within 20km the engine was back to itself. I then replaced the fuel filter as a precaution the following week.
The ISC only needs to be cleaned probably every 100000km if that, all when an idle problem arises., maybe more frequently if your running a oil based filter(unifilter, k&n etc). I just removed it and used mineral turpentine and cotton wall buds, also cleaned the throttle body with carbi clean spray.
Cheers....
Old 16-06-2007, 10:17 PM   #18
efgiar
rofl copter
efgiar's Avatar
carby cleaner or kero does the trick to clean isc, but alot of the time its in the computer, 2 capacitors dont work properly and plays with the idle.
GQ patrol.
thats all
Old 16-06-2007, 10:28 PM   #19
ILLaViTaR
ILLaViTaR's Avatar
Yeah actually I'm unsure about the ISC
The service receipts just say throttle body clean so it may be ISC time.
Also the only thing I havn't done that my old garage (kmart tyre and auto) is flush the fuel rail and injectors with cleaner, they charged $130 for this, how often is this necessary???
Also I put premium in it for the first time in a year so maybe that's it??? From safeway petrol.
I got a fuel filter but the other one was only changed 20 000k's ago, gregory's says
40 000k's so I dunno whether to change it or not
Old 16-06-2007, 11:39 PM   #20
Conrad
Are we talking about an EF/EL?
White exhaust usually means its running rich, does it not?
I have the same low idle problem. Is it a problem? Lower idle = less fuel being used
In all seriousness i would like to know the cause and solution aswell.
Conrad is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 12:43 AM   #21
ILLaViTaR
ILLaViTaR's Avatar
Nah, mines an ED
I thought black meant running rich.
Old 17-06-2007, 01:42 AM   #22
sexr6tasy
Did you let the car run with the radiator cap off for about 10 minutes to drain out the excess air or just put the coolant in put the cap on and start it up?
sexr6tasy is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2007, 02:06 AM   #23
ILLaViTaR
ILLaViTaR's Avatar
I havn't air bled it yet.
Havn't got a chance yet. I didn't drive it since I aint 18 yet and dad didn't have time to idle for 10min.
I'm gonna bleed the air tomorrow.
I leave the cap on loosely don't I?
Otherwise when the thermostat opens it'll all spit out or not cycle?
Would this make the exhaust sound odd?
Old 17-06-2007, 02:19 AM   #24
JC
Miami Pilot
JC's Avatar
Best $40 you can spend on this car is to go to supercheap or repco, and buy one of the Haynes/Ellery/Gregorys manual. They all have troubleshooting sections, and you will get answers based on your findings immediately from the book, instead of guesses on this forum based on little to no real information.
Seriously, it is just too hard to diagnose accurately what may cause a funny noise, or a low idle, if you can't hear the car. Every now and then, someone will guess at the right cause, but which guess are you going to know is the right one?
Ford Performance Club ACT
Old 17-06-2007, 10:57 AM   #25
ILLaViTaR
ILLaViTaR's Avatar
Yeah excactly.
The gregory's manual is very vague in places, I might purchase a more advanced manual.
Old 17-06-2007, 11:33 AM   #26
JC
Miami Pilot
JC's Avatar
Yeah excactly.
They're all vague in places though, as they rely on you knowing something about cars and how to fix them. Some of the trouble shooting, I just look at and go "must be something else - that's too hard". Sometimes going to a mechanic is required.
Old 19-06-2007, 12:58 AM   #27
gambino
bumps in the trunk
u didnt spill coolant on ur alternator, when i got my ed the hose thats above the alternator that connects on the water pump came off and sprayed on my alternator and i also had power steering fluid leaking on the alternator, that stuffed my alternator and eventualy died on me. i also suffered from bad idle from having all that **** going on to my alt, also got power spikes and random times. also replaced the rotor cap, ignition coil and started motor. and i run a higher octane fuel i get a real nice idle now. just a few sugestions
1994 NC Fairlane Ghia V8
1995 Ef Gli
gambino is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 11:55 AM   #28
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
Don't bother falcons are set up to stop any air lock in the water system. hence the little hose on you thermostat housing.
those manuals are not very good at trouble shooting your money is better spent on fixing the problem item itself,
Black exhaust means it is running rich, white steam usally means 1. its cold and the condensation in the exhaust it heating up. 2. the head gasket is gone, but as you have done compression test it is probly not that.
the low idling and sputtering is due to the battery dieing and the computer ECU being reset and the computer is learning from the 02 sensor what is happening it will run badly for 15min and it will eventually sort its self out.
Take it for a drive make sure you watch the temperature gauge if it starts to climb turn it off and let it cool down. i think that by taking it for a drive it will allow th computer to re set itself, all so wetting the engine bay some times causes the engine to Not start wjich is what may have happened plus a dead battery which made matter worse.
tristan
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
