Old 20-06-2007, 04:08 PM   #1
Morgz88
Default Tranny Capers
Got home last night after a 2 hour trip, car ran perfectly the whole trip.
Hadnt been home for more than 5 minutes when I realised I forgot to get milk.
Jumped back in the car and drove 2 mins to the shop and got milk.
Half way home from shop the car suddenly starts to rev out in Drive, as if it had just been put into Neutral but it was still in Drive. I'm like WTF?
Lost all gears, wouldnt engage at all.
Managed to roll home (lucky was all downhill).
Started car this morning all seemed fine till about 1 min into drive, same **** happened again.
Got a tranny kit and fluid for $70 and did the overhaul. Man was that fluid black and burnt plus only 3 liters drained out.
All running perfectly now, but how could that happen without any warning and why 5 minutes after a long trip and not during it?
Wouldnt it start to slip in drive going up a hill first if fluid is low and old?
Morgs.
Morgz88 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2007, 04:49 PM   #2
AUTickford
XD197
AUTickford's Avatar
Should be about 4.5 litres of oil in the trans because ive serviced mine a few times and thats exactly what came out each time,if the oil was really burnt you will need to service it again because the convertor would still have been full of burnt oil and it will contaminate the new oil.It sounds like there might be a leak if only 3 litres came out, check the rear seal[extension housing where the tailshaft goes in]
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2007, 05:00 PM   #3
RG
Back to Le Frenchy
RG's Avatar
Take it to a tranny specialist and get a full flush done on it, just make sure you tell them it already has a new filter so they don't sting you for that.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2007, 06:18 PM   #4
CMYAU3
Tyre Shredn
CMYAU3's Avatar
i put an oil cooler in my but could'nt be stuffed topping up the oil because its in a bit of a **** place. its been alright for the past 2 months but after i gave it a real floggn at calder. in drive from 1st to 2nd it revs out and then i have no gears. ill let it idle for about 30 sec (not that i have a choice) then it fixs itself .im getting the tranny serviced next week hopefully this fixs it. at first it was only eveyonce in while but its become a couple of times a week only in the mornings when its freezing.
CMYAU3 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 08:54 PM   #5
Morgz88
Could I maybe just give it anothe flush with 4 litres of fluid, or you recommend a full flush?
Was also interested in how much residual fluid was left after a drain and fill, how much fluid the convertor held.
Anyone know what is exactly involed in a full flush?
Old 21-06-2007, 09:00 PM   #6
mcnamg
mcnamg's Avatar
wasnt paying attention when i saw the title of this post thought i might have ended up on a porno forum or something
mcnamg is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 09:15 PM   #7
RG
Back to Le Frenchy
RG's Avatar
I think the converter holds about 15 litres so you are better off to just get the full flush done.
Old 21-06-2007, 10:05 PM   #8
accurate1
Actually the whole system only holds 10.5 litres (approx)
accurate1 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 10:13 PM   #9
FGII-XR6
FGII-XR6's Avatar
in a service they also chech and tighten the bands if needed if the fluid was burnt smelling pay the extra and get a pro to do it. thats far cheaper than a new or reco'd tranny according to the manual the tranny and convertor take 9L from completly empty (dry) and 4L for tranny only
Old 22-06-2007, 12:13 AM   #10
JC
Miami Pilot
JC's Avatar
Bands in an AU tranny - not what I've been told. It's all run by solenoids and valves.
Ford Performance Club ACT
Old 22-06-2007, 12:47 AM   #11
Peeler
RC NITRO TRUCK addict
Peeler's Avatar
if you have driven the car all the fluid will be dirty again
there is a cooler line under the radiator , with a connector .
drain the pan again , refill new fluid , undo the connector and place a hose on the end into a drain tub ,start it up and pump it out, till you have clean fluid usually around 12-15ltrs gets it clean , dont run for to long as the pan will run dry quickly, top up as you go, reconnect , recheck the level
XR8 250 PURSUIT ,silhouette, manual, hardcover/spoiler
FG F6 310 sdn XFT
SY T awd terry
LC GTR304 t350 9inch
VK BT1 LSX 454R p/glide 9inch
LX SLR LS3 p/g 9 current project
Peeler is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 12:55 AM   #12
FGII-XR6
FGII-XR6's Avatar
i have the workshop manual in front of me the front and rear bands are adjusted internally unlike older trannys like the c4 and borg warner 35 but they still have bands. They are now controlled electronically with solenoids etc instead of mechanically but the basic mechanical principal remains the same bands clutches and planetary gears etc ans of course we now get an extra gear and lock up torque converter. it's a matter or an old principal enhanced by modern technology
Old 22-06-2007, 09:55 AM   #13
accurate1
Who have you been talking to???????
Old 22-06-2007, 10:20 AM   #14
Silver Ghia
Silver Ghia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: As Silver Ghia his contributions to the AU and BA technical areas have been of high quality and valuable to the member base.
Hi guys,
Have a read of this thread. Its very imformative and shows how to service and flush transmissions:
http://www.fordforums.com.au/showthr...light=changing
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 12:58 PM   #15
Morgz88
Thumbs up
Any idea on the cost of a full flush from a specialist, so I can make sure I'm not being taken for a ride?
Thanks again for all the replys and info guys, it's all priceless. :
Old 22-06-2007, 03:30 PM   #16
GK
Walking with God
GK's Avatar
I agree with all who've recommended the full flush.
I had one done on the wagon a few weeks ago, was $250.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 22-06-2007, 03:34 PM   #17
burnz
VFII SS UTE
burnz's Avatar
i think you to late
your clutches are fried if the oil was black!
time for a clutch pack
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 10:25 AM   #18
sly
Sly like a G6
sly's Avatar
Then how come they toughen trannies by fitting Kevlar bands?
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 10:38 AM   #19
GK
Walking with God
GK's Avatar
There are bands in an AU auto, but they aren't adjusted anywhere near as much as in times past. In fact they are hardly spoken of, which may explain why the idea of them even being in an AU box seems unlikely!
I got this information from Dino, the owner of a Fluidrive business, which is where I get my auto work done.
GK
Now gone!
On LPG
