Old 20-06-2007, 10:58 PM   #1
private9
www.TUFFCARPARTS.com
private9's Avatar
Default How do you tell if your leads are worn out?
Hi All,
Just wondering how I can tell if my leads are stuffed? The car runs well, idles smoothly etc, but I'm getting the car serviced anyway, so thought I might as well get them done if they needed changing.
Having said that, I don't want to replace mine if they're nowhere near stuffed.
Will search some threads as to recommended brands etc.
Thanks,
Justin.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 07:45 AM   #2
StealthAu
I know its overkill, and a waste of cash, but I replace mine every 6 months (every second service).
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 08:37 AM   #3
Robe
Because it starts backfiring when on gas.
(That's why I wired those $5 air box springs on to the bottom of the box.)
Rob Ewart
Bog standard silver BF Wagon, except for the Elvis doll , on gas.
Victorian Rock'n'Roll Dance Association
www.VRRDA.com.au
2015 Victorian Rock'n'Roll Dance State Championships
23 May 2015, Furlan Club, Thornbury
Robe is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 09:17 AM   #4
LOWAU
___________
LOWAU's Avatar
You can tell if they are really stuffed if you run your car in the night and look for arcing across to your engine block. To be safe I guess change them every 70-100,000km.
You can also test them with a multimeter set on the OHM setting and test for resistance but it would be good if you have access to a new set so you could tell the difference.
LOWAU is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 09:31 AM   #5
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
I think its 10k Ohms for every 30cm? If they're above this they're stuffed.
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 09:40 AM   #6
XR351
Lov'n the conditions
XR351's Avatar
I agree, if your experiencing mild backfiring from the exhaust when listening to it from behind say at idle then maybe both leads & plugs are a bit stuffed. Leads are less likely to breakdown (ie previous thread 70,000 - 100,000km maybe change leads but spark plugs especially on LGP breakdown quick 10,000-30,000km at a guess) It sounds like engine is missing or popping slightly. Cheers :
XR351 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 09:57 AM   #7
GK
Walking with God
GK's Avatar
If the leads are breaking down, would you notice hesitation under WOT?
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 21-06-2007, 10:40 AM   #8
Oo_xrsx_oO
t i c k f o r d
Oo_xrsx_oO's Avatar
Generally one of the first signs they're on the way out, pretty scary when you give it a bootfull to get it through traffic or something and all of a sudden there's nothing there!
AUIII XR6 VCT
Liquid Silver / Manual / Leather / Momo Wheel & Shifter / Premium Sound / Lovells Superlows / Koni Reds / T3 Pursuit Rims / Pacemaker 4499s / 2.5 Inch Exhaust
Oo_xrsx_oO is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 11:53 AM   #9
GK
Walking with God
GK's Avatar
Under heavy throttle that's exactly what I've been getting!
My leads are being replaced as I type! I hope that sorts it out, otherwise, coilpack will be next.
Aaaaaaaaaaahhhhhhhhh the fun and games! LOL!
GK
Now gone!
On LPG
Old 21-06-2007, 11:56 AM   #10
Oo_xrsx_oO
t i c k f o r d
Oo_xrsx_oO's Avatar
GK
Yeah sounds like your leads have had it, do you get a popping sound sometimes when it cuts out? Always a good feeling when you know what the cause of a problem is, even better when its an easy fix.
AUIII XR6 VCT
Old 21-06-2007, 12:01 PM   #11
XR351
XR351's Avatar
If it was a coil pack stuffed the car would NOT run at all. Don't waste your money on a new coil pack if the car runs. If its missing replace the plugs first then if its still missing then gets some leads. Save your hard earned.... One thing at a time till you fix/find the prob.
Old 21-06-2007, 12:19 PM   #12
GK
Walking with God
GK's Avatar
I am doing exactly that.
Gas converter cleaned.
ISC valve cleaned on Monday.
Plugs replaced two weeks ago.
Today leads.
Hopefully that will be the situation sorted.
GK
Now gone!
On LPG
Old 21-06-2007, 12:20 PM   #13
GK
Walking with God
GK's Avatar
No popping sound that I can hear.
GK
Now gone!
On LPG
Old 22-06-2007, 09:15 AM   #14
private9
private9's Avatar
Thanks, I'll give that a try in the next few nights. We've had the car for 2 years or 25000 kays, and the leads looked a bit old when we got it. Mechanic said they were fine at the last service, but not sure if he tested them or not.
I might just get a set and be done with it, as the plugs are being done anyway as well. The car's going on gas soon too, so at least I'll have peace of mind knowing that I won't have any backfires straight up!
Old 23-06-2007, 07:25 PM   #15
private9
private9's Avatar
Thanks for all the advice everyone. In the end I figured they must be close to the end of their life regardless, so went out and bought a set of 9mm ICE leads. Will have them fitted next weekend hopefully, so I'll let you all know how it goes.
