Old 19-05-2005, 01:53 PM   #1
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
Default Help with ED H/lights going out
hey guys
ive got a problem my headlights randomly go out while driving ,ive traced it back to this relay block
when i fiddle with the wires the lights go out ,so im just wondering if you can replace that part it doesnt look like you can ,and where the wires go into the bottom of all the relays is there a trick to getting them out ive gently pulled on them but they wont come out ?? any ideas
and also i found this little thing
any one know what it is ,it looks like its been shorting out or something ,it's a bit burnt and very hot to touch some times ??
well if you can help me out that would be great
cheers jarrod
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2005, 01:55 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
The last pic is the offending part its a circuit breaker of sorts, get a new one should solve all your problems.
Old 19-05-2005, 01:57 PM   #3
neb
hibernating
neb's Avatar
probably not a bad idea to change the relay as well. that was causing my high beams to randomly go out. i bought the relay from repco
neb is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2005, 02:27 PM   #4
ned
Once shy... twice bitten
ned's Avatar
Check the female side of the relay block, they can sometimes spread a little and not make proper contact with the male terminals. I had the same problem a while back, pushed the female fins a touch closer together with a small screwdriver and done the job.
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11.
ned is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2005, 03:02 PM   #5
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
hey well i pulled it apart and found this
now my only consurn is the middle wire the prongs on the actual relay there are only four but the the bottom there are 5 wires ??? so i dont understand are there relays with 5 prongs ?? or am i missing something??
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
Old 19-05-2005, 04:24 PM   #6
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
well i cleaned it all up pushed the terminals together to get a better contact and cleaned the resetting circut breaker so i'll see how it goes
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
Old 19-05-2005, 08:35 PM   #7
galapogos01
eec tweaker
galapogos01's Avatar
your battery terminal is awful close to the body there....
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2005, 08:51 PM   #8
DanXR6T
Eat more peanuts....
DanXR6T's Avatar
I'll put my money on the circuit breaker.. it should slot into the side of the relay block..
As Dellboy said.. About $27 from Ford, less from a wrecker or auto shop..
'04 Falcon XR6T Ute, Envi, K&N filter, F6 Intake, Twin 2.5" exhaust...
Formerly owned:
'99 AU Falcon Ute
'88 EA Falcon GL
DanXR6T is offline   Reply With Quote Multi-Quote with this Post
