Old 16-08-2007, 02:54 AM   #1
sirdavepope
All Black Ford attack
sirdavepope's Avatar
Default Window scrape
Driver's side window start scraping when it nearly 2 inches from getting to the top. Washed it the day before. Maybe a bit of grit?
sirdavepope is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2007, 07:59 PM   #2
Jokular
Jokular's Avatar
Could be..
Is it scoring the glass? If so it might be grit or something.
It might be the rubbers have hardened on either side of the glass.
I usually use silicon spray lube on the rubbers after i wash the car.
Read the 'common problems' sticky there might be more info. on windows.
Jokular is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2007, 08:23 PM   #3
blacklabel
blacklabel's Avatar
Jokular's onto it.
I use CRC silicone spray on all my rubbers and window surrounds too- it really treats the rubber and provides a nice "dry" lube too.
It's also great on your mudflaps and tyres too- a psst- psst here,and a psst- psst there!
Good as new! :
blacklabel is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2007, 08:56 PM   #4
private9
www.TUFFCARPARTS.com
private9's Avatar
I third what has just been said!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2007, 11:38 PM   #5
waggaclint
waggaclint's Avatar
is it just a scraping type noise inside the door...and do you have power windows?
if so i sugest that it could be your window regulator the cables etc stuff up and youl need a new reg.....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
