Old 03-09-2007, 08:22 PM   #1
quigs
Default tuning probo
G'day all, and thank you for having me on board.
Our 7th Falcon, an AU 98 Futura, has got me a bit foxed, it's running rich.
Pulled out the spark plugs yesterday, black as.
Cleaned them up and did a 250k run; pulled 'em out just now, and the plugs are sooty....
I'm wondering if any of you experts can send me in the right direction as
to tuning...
I really would appreciate your advice,
the missus is giving the rounds of the kitchen as its her car and is sucking juice like there's no tomorrow.....and blowing black smoke...
I don't know how to tune this, sorry, my ride is a ZC 351 with a carby, but the electronic Falcon is a bit beyond me..
Thank you for helping.
quigs ?
quigs is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 08:25 PM   #2
gfanga
thermostat could be stuck open check that, also could be map sensor start with that man
gfanga is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 10:06 PM   #3
FGII-XR6
FGII-XR6's Avatar
could be the O2 sensor or temp sensor both will make it run rich
Old 06-09-2007, 07:47 PM   #4
bellagirl67
Hi I had the same problem with my 2000 AUII.Took it to Fords and they replaced the fuel pressure regulator and that fixed it. I was getting maybe 150 - 200kms a tank!!! Hubby took out the plugs and they were black as and had only been in 2 weeks, it was also blowing heaps of black smoke. The fuel pressure regulator controls how much fuel to give the injectors and mine was stuffed so it was pumping full fuel to the injectors. Cost me(hubby really) $450 to get fixed. Since having it done my exhaust is running grey and I now get 450 - 500 kms a tank. Hope this helps. Try getting a wreckers to fit one it might be cheaper. Good luck.
bellagirl67 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 07:50 PM   #5
Casper
Contributing Member
Casper's Avatar
Originally Posted by bellagirl67
Since having it done my exhaust is running grey ....
I hope not. Only lead based fuels leave a grey exhaust. Unleaded is black no matter if its rich, lean or spot on.
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 08:01 PM   #6
sly
Sly like a G6
sly's Avatar
Maybe it's blowing grey smoke instead of black...
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2007, 09:22 PM   #7
bellagirl67
Well according to Fords its running fine!! The car has never run this good. And I think I know the difference between leaded and unleaded petrol.
Old 08-09-2007, 09:25 PM   #8
Casper
Contributing Member
Casper's Avatar
I'm sure it is and I'm sure you do....
but unleaded fuel never leaves a grey exhaust.
Old 10-09-2007, 03:37 PM   #9
james22
With da Warlords
james22's Avatar
That could be the problem with my mrs car then, never been able to solve it. She is lucky to get 250km per tank and she drives like, well a girl lol.
Its got 150,xxx km on it, and original 02 sensor by the looks of it, so thats my first port of call, but if that doesn't fix it what else could it be.
P.S - only started running really pig rich after I put the XR6 cam in it out of my new engine
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 04:21 PM   #10
sly
Sly like a G6
sly's Avatar
A blown T-MAP sensor will also cause rich running. If it's a pig to start, needing a lot of cranking over as well, the TMAP would be a suspect.
I found my hot idle was always rich with a bigger cam than std, but it was only recently I found idle too rich with the std cam too, at 315,000k's still with the original O2 sensor. Changed it and it's all good.
Sleeper, anyone?
